Question about KitchenAid KP26M1X Stand Mixer
Slipping gears I believe the reason the gears are slipping and The mixer will not handle a load is because the bushing in the top of the gear housing keeps sliding down onto the main gear shaft. How can I get this bushing to remain in the top of the housing where it belongs?
    Scholar:
  • KitchenAid Expert
  • 188 Answers
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
Posted on Aug 25, 2008
donmeanie
SOURCE: K45SS leaks lubricant
From what I see, the "O" ring on the vertical center shaft that could be the problem and/or the transmission case gasket. I will let you know what i find when I venture into my mixer. Also, if you decide to try and repair your mixer, plan on replacing the nylon worm gear while you have it apart. Aparently they are known to strip or break. The cost should be minumal for all parts depending on your model, worm gear is between $14.00 to $25.00, the "O" ring maybe $1.00 at your local hardware store and the transmission gasket should be about $5.00. Mixer grease is $17.00 but I think I can find a sutible substitute locally. Check out http://www.goodmans.net/get_list_10.htm for more information and parts.
-DM
Posted on Nov 02, 2008
  • 118 Answers
SOURCE: Agitator Shaft in Planetary
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
Posted on Nov 30, 2008
ricardok45
  • 135 Answers
SOURCE: trying to replace the gear worm on a kitchenaid mixer ksm5ps
Hi. Go to the kitchenaid website, search for the parts catalog for your model of mixer. Download the file and use these expolded diagrams to get to the worm gear shaft. You'll have to remove and save the grease when you remove worm gear. This is a messy, but necessary job.
You don't say what caused the worm gear failure in the first place. If you were making a heavy bread dough when it failed, you need to look further than the worm gear.
Once you have removed the top cover of the mixer, look at the now exposed transmission housing at the top front of the mixer. If this is a plastic housing, check it carefully for cracks. If you find cracks anywhere on this housing, you have discovered Kitchenaid's cheap plastic housing. If your warranty has expired, remove this trans. housing. If you've never done this type of work before, I recommend that you take a digital photo at every stage of part removal, as these photos will help you when you re-assemble the mixer.
If you find that the trans. housing has cracks, this is the direct cause of your worm gear failure. You must check for further damage to the worm gear bearings and their seats. Look for cracks and/or pieces broken off of these bearings. Re-assemble in the reverse order using the photos and the drawings to guide you.
Be prepared to wait for a month for your parts to arrive. Insist on a new METAL housing for the under engineered trans. housing. Kitchenaid is now owned by Whirlpool Corp. The product is but a shadow of the way Hobart used to manufacture these mixers. If this solution has assisted you. please rate it. Good luck! ricardok45
Posted on Mar 11, 2009
woobie dog
  • 1273 Answers
SOURCE: Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
Posted on Aug 06, 2009
Squeak while mixing.
That sounds like the accessory drive is binding in the bush in the front housing. Don't use it and think seriously about getting it to a Kitchen Aid service agent. No good will come of forcing the issue. If you never use any accessories in that front drive you could consider asking them to remove the gear and put it back together again without it. If you force it to continue eventually the fuse gear will fail and you could even wreck the gear that drives the planetary. The accessory gear will need to be replaced and if the bush is damaged enough the top housing will need to be replaced as the bush is not available separately.
Mar 03, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
My kitchenaid artisan mixer doesnt run fast enough
It may be seizing up the bush that your accessory drive runs in, if you can see grindings in the front by the square drive that is a sign. Here in NZ that bush is only available as part of that whole top cover/housing. The accessory drive gear will also need to be replaced.
Feb 17, 2014 | KitchenAid KSM150PS Artisan Series Stand...
My KT2651xmg was unable to take on heavy loads without the gears slipping. I took it to the repair shop but was told no parts avalible. I took it apart and cleaned it up and it worked fine for 8 months. It...
You could always buy her a new model and have it painted Martha Stewart Green before you present it to her. To fix the old one you need to identify which parts are slipping and require replacement before we can help you out with a repair solution. It may be gears, it may be driving pins, it may be bushes or bearings or housings or a combination of all of them.
Nov 03, 2017 | KitchenAid KT2651X Epicurean Stand Mixer
I have a hobart a-200 mixer that had the brass drive gear go out. I rebuilt the transmission and used a parts breakdown to clean out and rebuilt the whole tranny. Now I have no 1st gear. Under a load...
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
May 20, 2010 | Hobart A200 Stand Mixer
Hobart d300 spins but slips under load
sounds like you have a sheared key in one of the gears. which speed is it slipping in or is it all 3speeds
Dec 04, 2009 | Hobart D300 Stand Mixer
Thumping Noise Under Duress
Hi. Your problem probably lies in the plastic transmission housing. This cheap piece of plastic has no business in a high priced mixer, as it has two important shafts that depend on the integrity of this housing for their bearing seats
Remove the top cover from the mixer. At the front top of the mixer is the trans. housing. Examine this housing carefully for cracks. If you find cracks, then you have new damage inside the mixer. If, when you replaced the three gears, I suspect that you did not discover the cracks in the trans. housing and reinstalled it after you replaced the gears, or you may have missed internal damage from the first breakdown.
When this cheap plastic part fails, it can destroy the worm gear, it's bearings and the bearing seats and possibly more.
Kitchenaid's replacement housing is made of metal. Kitchenaid markets these mixers saying it can handle bread dough. The ugly truth is they cannot!
You must open the unit up, remove and save the grease if it's relatively new. You must check every moving part in the mixer's transmission. You have to remove grease from these parts in order to find the damage. When you have the unit repaired, sell it!
I had the same problem with my mixer. I replaced all of the broken parts, and sold it. Since then, I bought a used Hobart N50 ( 5 quart), and an A200 (20 quart) mixers, both of which are commercial mixers. Both of these can handle heavy dough and they do so with ease.
Kitchenaid, to this date, have refused to recall these trans. housings, even though thousands of these cheap plastic housings have failed. Good luck with this saga!
If this solution has assisted you, please rate it. ricardok45
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Repairing a kitchenaid 6qt mixer and replaced worm gear. parts list shows a thrust washer needs to be there but it won't fit. after a closer look it appears that I have two back bearings for the worm gear...
Hi. Go to the whirlpool.com website, for some insane reason they don't list their mixers, enter a search for mixers, then find your model #. Look for a parts catalog. Look at the "exploded" drawings for the transmission area. There you'll notice that there are Front and Rear bearing locations. This drawing also shows the correct place for the "washer". Also, the front and back bearings may look alike, but the're not. Every part needs to be in it's correct place or damage will occur when you start it up, or when you place the machine under load. Let me guess...The original PLASTIC transmission housing broke causing damage to the worm gear assembly. If this is the case, your replacement transmission housing should be made out of metal. If it isn't, call customer service and demand that they send one. The plastic housing has no place in a Premium priced mixer, especially when they advertise that the mixer can handle heavy bread dough. Finally, check the bearing seats, when the worm gear failed it may have also damaged these seats. It happened on my Kitchenaid. Good Luck!
ricardok45
Nov 22, 2008 | KitchenAid KP2671 Professional 6 Series...
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Nov 10, 2008 | Black & Decker MX50 PowerPro® Mixer
Food Mixers Logo
137 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
