Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer spins to a stop.
When the washer spins at the end of the cycle, it spins getting slower and slower until it just stops...Should it stop this way or have a brake that stops it when it gets to a certain slow speed? Its new to me and I'm not sure this is the way it should work?
  • Frigidaire Master
  • 5,323 Answers
The brake engages the clutch and no it does not stop right away.
Posted on Mar 31, 2015
  • 209 Answers
SOURCE: Washer won't stop spinning
i am a recently retired appliance engineer of 20 years, if the fault is not right after he has called then write to the manager of the company, if he is sole operator then write to him, explaining it like you said above, ask that the engineer stay and watch till the very end of the cycle as thats where the fault is, if he has already worked on the machine fetch them back? alternatively just ask a different engineer who knows what he is on about, to me this sounds like a circuit board problem either the timer or main pcb module, i presume this is a computer control washer with a digital display, hope this has helped you at least as to where to start, thank you.
Posted on Sep 13, 2007
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
Nicesuit
  • 61 Answers
SOURCE: Washer does not spin at the end of the cycle
check that you do not have the crease gaurd or rinse hold button depressed? does it spin at all can you put it on a spin cycle with clothes in and no clothes in?
Posted on Jul 23, 2009
  • 410 Answers
SOURCE: Affinity ATF7000 washer high speed spin not
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
Neptune washer won't stop
this is a major control fault. replacement of the control board will be needed in this case. it has failed.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Cycle runs normally but the washer does not stop after spin
I don't know specifically about your machine but I think the problem is with the door lock. Again, on most machines with a shakeout it can go on and on until the door unlocks. Does your machine have a door UNLOCKING solenoid or does the door lock just lose power at the end of the cycle. It may be that you just have a very weak solenoid to unlock the door.
Feb 18, 2008 | Maytag Neptune MAH6500A Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
