Question about Slice Ceramic Safety Cutter
Auto retract slice cutter slider that moves blade out will not latch. I have to hold it in place with my thumb and so can't make any cuts. Am I missing something?
    Problem Solver:
  • 9 Answers
If I am reading this correctly, your answer may be that the cutter is designed that way for safety. "Auto-retracting". You find it in some utility knives that often store employees are required to carry so they won't "hurt themselves". Annoying, really. Try buying another cutter that is not an "auto retract"-- or get used to using your thumb for the purpose of holding the slide so the blade stays exposed.
Posted on Jul 06, 2014
Husqvarna viking sewing machine
If the machine was just recently serviced and the thread cutter stopped working after the service, take it back immediately! They should be able to fix it for you.
Aug 25, 2016 | Husqvarna Sewing Machines
AUTO TRUNK LID DOES NOT FULLY CLOSE
adjust the latch so that the catch will lock over properly. You may need to use a round bar ( screwdriver blade ) Place it under the latch and while pressing on the release button pull the latch out to the open position. The latch may be 1/2 closed before the boot is put down and the latch will not go any further
Feb 15, 2014 | Cars & Trucks
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
How do you compress rear brake caliper
these calipers take a tool you can borrow from your local auto parts store if they are advanced auto or autozone at least. it will turn the calipers in they are really big screws and cannot be pushed in.
Dec 13, 2010 | Jaguar XK Cars & Trucks
Sunbeam toaster model 6253 After placing two slices of bread and pushing down the leaver, leaver does not stay locked. What can I do to fix.
This is a maechanical fault and all you need to do is look for a lock that clicks to hold the tray down .This latch is controlled by the bimetal which when hot moves off and releases the tray.
So this strip could have moved off or damaged with use.
Might have to replace or try to repair to keep it in the lock postion..
Sep 20, 2010 | Sunbeam 3822 2-Slice Toaster
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Auto Cutter
Part # ACC-230kit
or send in for service 95.00 flat rate repair.
Agson 856-751-9048
May 01, 2007 | Citizen CBM 1000 thermal Printer
Slice Ceramic Safety Cutter Logo
602 people viewed this question
Top Slice Cutter Tools Experts
JOHN LAPIER
Are you a Slice Cutter Tool Expert? Answer questions, earn points and help others
