Question about Kocaso M766 Dual Core 1.5Ghz Dual Camera Android 4.2 Capacitive Tablet PC Black
My m766 has a clear screen
Will not show anything on the screen
My granddaughters nextbook 8inch will not display anything the on the screen it is just blank
If it wont show anything then there may be a problem with the launcher( the program that loads all of your apps and widgets). If you cant get to the settings then consider having a tech professional look at it and dont touch anything if you have no clue what it does i've learned that the hard way.
Jun 29, 2014 | Nextbook Premium 8 Se Android
My trio stealth -9 shows first screen with that on it next screen shows@dual core then it want do anything else what and how can I fix this
Hi, try to connect it to your computor, and try to access....if nothing, then you will have to do a software redo.....
Jun 21, 2014 | Tablets & eReaders
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
My Irola tablet will turn on but it will not load anything it just shows the Irola word on the screen then goes blank?
Most likely the battery is shot. If you could, try to power it up with the adapter supplying power. If this is successful it indicates that the battery is done for and no longer holds a charge. Most of the batteries on small, inexpensive tables only last for a couple of years. Yours may have used up it's life waiting in a warehouse. I have generally been unable to find replacement batteries for these tablets. There is a company in China that makes most of them as custom runs for small companies and does not stock replacements. You may also try to do a "factory reset" while the "powering up" logo is showing, find and press the reset button while using the power adapter for juice. If you manage to get it to run on the power adapter, and find that the battery is shot, there is little chance of portable use anymore.
Apr 15, 2014 | Coby Kyros 716829701508 Tablet PC
My tablet runs on but dose not show anything on the screen except for tap for calibration
READ what it says. IT DOES NOT SAY touch screen. IT SAYS touch circle. THEN you need to touch the crosses.
Mar 18, 2013 | Tablets & eReaders
My ematic eglide steal 7 is stuck on the android screen can i do something
I HAVE AN IRULU 10.1" TABLET AND THE SCREEN SHOW CALIBRATE AFTER TAP BUT DON'T DO ANYTHING ELSE WHAT I SHOULD DO
Aug 31, 2012 | Ematic eGlide Steal 7" Android Tablet with...
Kocaso M766 Dual Core 1.5Ghz Dual Camera Android 4.2 Capacitive Tablet PC Black Logo
26 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
David Payne
David Payne
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
