Question about Canon Office Equipment & Supplies
Canon mg4250 pdf problem
I insreted a sd card with pdf files to printing, but the printer not printing, couse is too big
Soulvisitor
  • 1113 Answers
SOURCE: Canon iR 3220 printer problem with PDF files
Sound like a driver issue, reinstall and check that it is correct one.
Posted on Nov 09, 2007
EPIJAB
  • 89 Answers
SOURCE: Does not print pdf files
It sounds like it is a printer memory issue. That printer comes with just 64MB of memory and PDF files are complicated for most printers. Try printing a few pages at a time for that PDF file and see if that works. If so than it is a memory issue.
Posted on Jan 24, 2008
worldvet
  • 859 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: Unable to print PDF files
use the PS driver for that
Posted on Feb 24, 2009
herminio_hal
  • 210 Answers
SOURCE: biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Posted on Aug 20, 2009
Canon mg4250 has stopped printing have put in new ink cartridges. What todo?
Press the power button 15 seconds, the printer will perform a new reception at the new cartridge in pairs. Wait a while until the light not blinking
Nov 11, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
How do I simply print single page on screen. currently when I press print all pages concerned are printed in reverse order.
Go into the computer's Control Panel. Find your printer (may be under Device Manager) and change the default settings.
Mar 17, 2016 | Canon PIXMA MG4250 Inkjet Multifunction...
My printer will not print and it always says on my chromebook 'printer offline'.
you need to link the printer with the computer. is this hardwired or wifi? if wifi follow the computer and printer directions on how to set up wifi connection. if hardwired you may have a bad cable
Sep 22, 2015 | Canon PIXMA MG4250 Inkjet Multifunction...
Error code 1003
How to Fix Canon Pixma Printers Errors http://windowstechies.com/-/en/filename/?t=1&k=canon%20pixma%20printers&m=b&u=&c=55860044070&file=canon%20pixma%20printers&gclid=CJvDiunjrMUCFaSWtAodLWkA_g
May 06, 2015 | Canon PIXMA MG4250 All-In-One Printer 9.9...
Do you have a manual for PIXMA4250series
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG4250.aspx?type=manuals
Jul 19, 2014 | Canon PIXMA MG4250 Inkjet Multifunction...
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Question Mark Appearing on Canon Selphy printer screen
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Jul 30, 2009 | Canon SELPHY CP740 InkJet Photo Printer
old marine
old marine
