Question about Motorola Mobility MBP33 Baby Monitor
Mbp36 camera not moving
Camera moves side to side but will not move up and down - motor is working though
    New Friend:
Could you finally fix it? I have the same issue and would like to know how to fix it.
Thank you
Posted on Jul 20, 2017
My power window will not work is there a fuse that controls all windows
There is a fuse for windows. However, if only one window is non operational, there is either a short specifically affecting that window or the motor for the window is broken.
Dec 08, 2015 | 1996 Jeep Grand Cherokee
Electric window not working
one power window not working could be window switch or window motor see if other windows will work from master switch on driver side if yes window switch is faulty,if driver side window is the one not working.check see if power going to switch and window motor the window motor could be in a bind remove disconnect the glass from window regulator see if window moves up and down not bind if yes windows move up and down the window motor is faulty or window regulator bad.
Sep 17, 2012 | Ford Ka Cars & Trucks
I have a 96 Honda Civic EX coupe. The passenger window will not go up or down from the drivers side. It will not go down from the passenger side. It is currently up. From the passenger side it will move up...
Hi Frito and Fion, Does the window work in any direction from either control. If it does that will mean the motor is undamaged. The most common problem is the switch. Get another, new or second hand and try fitting that. If the motor has burned out it will have to be replaced. Try the switches and if that fails we'll go through the bigger job together. Regards Johngee10
Jul 17, 2011 | 1996 Honda Civic
Power mirrors not working, have tried moving them manually (2001 Ford Crown Victoria). Both sides only goes down, not up.
If the mirrors only move down and not up I would suspect the mirror switch , the mirrors use one motor to move the glass up and down,and another motor to move them in or out , and if the mirrors move down the motors are working.the only other possible problem would be a wiring but highly unlikely due to the fact that the turning the motors in a different direction is done by switching the polarity to the motor which requires both wires to be good to make the motors move in the down direction ..check the mirror switch I am sure you"ll find that"s your problem
Dec 29, 2010 | 2001 Ford Crown Victoria
Electric folding door mirror not working
Try helping the mirror move by hand. The pivot rusts from not being used. Gently work it around.
Feb 03, 2010 | 2004 Land Rover Range Rover
Driver side power window only moves up a little bit at a time
Yes there is a problem with ur window motor. You should have an auto electrician to check it out. There are alot of things that can wrong with the motor though. If u want, u can remove the motor and connect it directly to the battery and observe how it operates. If it operates the saem way when winding up, it might need repairing or replacing
Jan 06, 2009 | 1993 Oldsmobile Cutlass Ciera
Buttons don't work correctly.
the directional button need to be replaced. www.fixphonenow.com can replace for $55.
Nov 16, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My front driver side power window is not working. One Minute it wont roll down but I can hear the motor. Then the next minute it was working fine. now the window is lose and i can move it up & down by...
you have to replace the window regulator reason why is because the cable ripped which would cause the motor to work without moving the window up or down .. regulator is the cable and the rails were the motor makes the woindow move up and down on. you have to replace it.
Aug 14, 2008 | 2001 Chrysler PT Cruiser
Motorola Mobility MBP33 Baby Monitor Logo
605 people viewed this question
Top Motorola Mobility Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
