Question about AO Smith 1.5 hp 3450rpm 56J Frame 115/230 Volts Hayward Northstar Swimming Pool Pump Motor - Electric Motor
Engine knocking noises
Making knocking noises
  • AO Smith Master
  • 1,631 Answers
Impeller could be plugged?
Diffuser may have become misaligned and hitting the impeller?
May have sucked up some foreign debris?
Knocking could be a bad bearing.
Posted on May 18, 2014
99 olds.intruge 3.5 engine
loud knocking internal lower part of engine usually means [ rod knock ] --bad wrist pin -spun bearing -or piston ring]s] --that the worst other can be timing failure --or component failure --you need to isolate the noise and diagnose from there
Oct 01, 2016 | Cars & Trucks
Crown victoria making knocking noise
Listen to the engine, if the noise is down low it is rod if it is up high it is valves. IF it is rod knock it will eventually throw the rod.
Feb 03, 2014 | 1993 Ford Crown Victoria
Why is my transmission pan is making knocking noise
The reason why your vehicle is making a knocking noise is probably because your valves need adjusting.
hope it can help you and if you need a diagnostic tool you can click here: chinasinoy.com
Nov 05, 2012 | Cars & Trucks
Knocking noise in engine of 2002 Nissan maxima
This is hard to say with hearing the noise but try to pin point the noise , is it coming from the top or bottom of the motor , the knocking noise could be a bearing in the lower motor or may be something else making it sound like a bearing,
Oct 05, 2012 | 2002 Nissan Maxima
Not getting oil to the pistons. Making knocking noise. Wont stay on.
Hello
Has the engine been run low on oil? Does the knocking get louder as the engine warms up? Have you had a automotive technician listen to this noise? Pistons don't really knock, the bearings in the engine called the crankshaft and piston connecting rod bearings do make a loud knocking noise, if that is the case the engine must be removed from the car and rebuilt.
Sep 23, 2011 | 1998 Honda Civic
I recently got a oil and filter change now i hear knocking noise
If the oil has been changed, why are you putting more oil into the engine? Does the engine use/burn oil, or have an oil leak? If you have none of these problems, then you may be overfilling the engine which is just as bad as no oil.
Jan 16, 2010 | 1995 Buick LeSabre
MAKING NOISE AT CENTER OF TOP ENGINE UNDER MANIFOLD LOUD NOISE
Is it a ticking or knocking noise? or does it sound like something is leaking could be a bad manifold gasket which would be better than a ticking or knocking.
Jul 08, 2009 | 2005 Jaguar XJ-Series
AO Smith 1.5 hp 3450rpm 56J Frame 115/230 Volts Hayward Northstar Swimming Pool Pump Motor -  Electric Motor Logo
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
