Question about Scuba Diving & Snorkeling
Archimedes penta 550
As adjusting the carburetor? On the third day of the third running of the engine cylinder crashes down? What should I do?
  • 11 Answers
SOURCE: running on two cylinders only at idle
sounds like the idle circuit in two of the carbs are plugged up or the carburetors need synchronization
Posted on Jun 18, 2009
  • 8 Answers
SOURCE: Tecumseh TC200-2026C carburetor
Rule of thumb for high speed is turn in til tight and back off 1.5 turns
Posted on Jan 08, 2010
budgie140
  • 501 Answers
SOURCE: unable to adjust carburetor after overhauling, engine idle
most modern carbies have fixed jets.some you can pry off the caps and adjust,but usually if you need to adjust carbie,youve got other problems.stale fuel,not enough compression,vaccuum leak,spark plug faulty[oiled up]carb gaskets letting in air,needle valve adjustment causing diapragm to not open it enough.used the wrong gaskets in the kit[sometimes they have different model gaskets in one kit
Posted on Jun 29, 2010
  • 3567 Answers
SOURCE: I am trying to determine
Yes, it is the cam chain tensioner. With the engine off, just loosen the tensioner lock bolt then strongly tap a few times on the tensioner casing with a screwdriver handle. This will free up the spring loaded tensioner. Now just re=tighten the tensioner lock bolt and you're done. Please rate my answer. Thanks. tombones49_157.gif
Posted on Jun 05, 2011
  • 120 Answers
SOURCE: show me carburetor for renault scenic 1.6 rxe
w-40 cleaner it will clean
Posted on Jan 20, 2014
Yamaha XJ 550 Seca will not run without choke
Hi, Joseph and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
81 XJ550 Seca Won Idle
https://www.reddit.com/r/Fixxit/comments/3qtw18/1982_yamaha_xj550_seca_startingidlefuelline_issues
DOWNLOAD YAMAHA XJ550 Maxim Seca REPAIR SERVICE MANUAL Download Manuals... $10
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Aug 02, 2017 | Yamaha Motorcycles
I have a Briggs & Stratton Vanguard 16 HP motor. It idles fine and it runs OK at high RPMS. But it backfires thru the carburetor during accelerating. Any suggestions?
On some float-type carburetors, you can adjust the air-fuel mixture and engine speed at idle. Check for an idle speed screw designed to keep the throttle plate from closing completely, and an idle mixture screw that limits the flow of fuel at idle. If your carburetor contains these screws, proceed below.
  1. With the engine off, remove the air filter and air cartridge.
  2. Locate the idle mixture screw and turn it clockwise until the needle lightly touches the seat. Then, turn the screw counterclockwise 1-1/2 turns.
  3. If your carburetor has a main jet adjustment screw at the base of the float bowl, turn the screw clockwise until you feel it just touch the seat inside the emulsion tube. Then, turn the screw counterclockwise 1 to 1-1/2 turns. Replace the air cleaner assembly and start the engine for final carburetor adjustments.
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow . Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed , set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle , hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture .
May 02, 2017 | Briggs & Stratton Briggs Stratton Intek V...
What should the Float Height in my carburetor be?
Floater height i have adjusted to 2/3 level of all carb reservoirs individually and to date it has been performing to the best. 23km/ltr dual carb GS450E.
Jul 29, 2014 | 1981 Suzuki Gs 550 L
My bike runs good up to third gear then when you go to forth gear the bike struggles almost like a cylinder is miss firing in i had the engine light come on when i down shift the light gos off have yo
I believe you have a carburetor. There should be a rubber boot from the carb, to the airfilter. the boot may have come loose for the carb. and is taking in to much air.
Mind did the samething when it reached higher rpms...
Jul 15, 2014 | 1998 Yamaha Royal Star XVZ 1300 A
Archimedes 550
try your local napa dealer .they have a marine division.
Jul 07, 2013 | Boating
RUNS ROUGH-BACKFIRES STARTS GOOD THEN DIES-IS IS IN NEED OF CARBURETOR ADJUSTMENT OR IS IT POSSIBLY VALVE ADJUSTMENT? THERE APPEARS TO BE NO WAY TO ADJUST CARBURETOR AIR FLOW AS OPPOSED TO OTHER...
In a 2-stroke engine, the valving is done by the mechanical relationship of the piston position in the cylinder. No adjustment is possible other than grinding the cylinder ports or changing the piston skirt shape. You need to check the fuel filter (in the tank), air filter, and muffler for plugging. Because the engine is designed to burn a small amount of oil with the fuel, the muffler tends to plug over time. Check the fuel lines for decay or other damage. The carburetor has a rubber diaphragm in the lower chamber that decays over time as well. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors that are typical of chain saw carburetors. Good theory and troubleshooting information. 2-stroke engines are picky about air leaks behind the carburetor. Hope some of this helps!
Aug 05, 2010 | Garden
1981 550 suzuki one cyclinder is dead has spark and fuel and bike runs but start extremly hard seems cold blooded
Check compression of cylinders, all should be close the same. Swap spark plugs and check if problem cylinder moved. If bike sits for long periods of time then most likely it will be a plugged carburetor.
May 20, 2010 | 1984 Suzuki Gs 550 L
Need to know how many turns do i turn out the needle valves on the 11 hp briggs @ stratton. need to know for everyone. thanks
ADJUSTING THE IDLE SPEED AND MIXTURE
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow (image A). Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed (image B), set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle (image D), hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture (image C).
Sep 18, 2009 | Garden
Running on two cylinders only at idle
Jun 18, 2009 | 2004 Honda Shadow 400
Scuba Diving & Snorkeling Logo
230 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
