Question about E-Machines Computers & Internet
Laptop dvd drive ejection mechanism is misaligned
Drive's ejection mechanism is not working
krihard
  • 407 Answers
SOURCE: cd/dvd drive ejected every 5 minuts
hi tray problem replace it ............
Posted on Dec 28, 2008
SOURCE: Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
I was having the same problem a few months ago. I had another vcr on top of the unit. My son told me nothing should be on to and sure unough when I took the weight off it worked just fine. Hope it works for you.
Posted on May 20, 2010
  • 356 Answers
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
Posted on Jun 03, 2010
  • 3 Answers
SOURCE: vod102 eject mechanism faulty need to
my dvd saund is not work because FM off
and my remot control is lost
what i can do
Posted on Dec 19, 2010
  • 5 Answers
SOURCE: Cannot eject DVD drive
on the dvd drive below the tray normally on the right hand side there is a little hole get a pin or something to fit the hole and insert it into it while doing this the disk tray should manually open this should allow you to get your disk out :)
Posted on Jan 19, 2012
HP Pavilion DVD player won't eject but plays the dvd
Try goint to My Computer and right click on the DVD player. If the eject works, the external eject switch is not working. If not, the mechanism is misaligned or damaged.
Oct 15, 2014 | HP Pavilion Computers & Internet
Tip
Troubleshooting Laptop Optical Drive Issues - CD/DVD Not Ejecting
Symptom
My laptop's CD/DVD tray won't eject when I hit the Eject button.
Diagnosis & Solution
If this happens while the operating system is running, there is a possibility that the drive may be blocked or disabled in software. In order to eliminate this possibility as the root cause of the problem, restart the laptop & hit the CD/DVD's Eject button. If your CD/DVD's tray did not eject, there is a possibility that the drive is not properly seated in the bay.
When the CD/DVD drive is not properly seated in its bay, it might not be connected to power. If the drive is in a swappable bay, try removing it & re-installing, & make sure that the release latch snaps to the locked position when it is installed. However, if the drive is permanently mounted, it shouldn't break free of its connector unless it is not secured in place. This can happen if the CD/DVD drive is secured with a single screw which was removed in an earlier repair & never replaced. The drive can function & stay in place for months without being secured, because it's a tight fit & the power/data connector tends to hold it in place. But occasionally, it might become loosely connected with the power/data connector.
If the tray doesn't eject even when the CD/DVD drive is seated properly in its bay, then the last resort is to power down the laptop & use the emergency release pinhole on the front faceplate. You can do this with the drive installed in the bay, but if it's the swappable type, it's easier to do with the drive out & on the table. Straighten out a length of a paperclip that's just thin enough to fit through the hole, & gently insert it. Listen for the release click & try to feel it through your fingers. When the tray releases, it may spring out half inch, or it may barely move at all, so you have to get a hold of the front of the tray to pull it out.
If a disc has come apart in the drive, either because it shattered or a stick-on label lifted off, getting all the bits out of the CD/DVD drive & getting it working again isn't a high probability, so don't test it with a disc of any value after attempting the repair. If it's an electrical/mechanical failure of the ejector mechanism, repairing it yourself isn't practical.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 31, 2010 | Computers & Internet
I have dell studio-15 and lately the CD/DVD drive continously ejects any CD/DVD without reading it. It cannot be read. I cannot write onto any CD/DVD either.
1. Try to boot to your computer using the Operating system disk see if the OS disk ejects try step 2
2. Try to go to the BIOS by tapping F2 upon boot see if the cd/dvd drive ejects
3. The reason for this if the problem is reoccuring outside of windows then the problem is mechanical and cd/dvd drive needs to be replaced
4. Else we need to do Operating System Reinstall or format the hard drive
Thank you for choosing
Jun 14, 2011 | Dell Studio 15 Laptop
Dell studio 1537 slot load dvd drive when cd is iserted there is a clicking and whirring sound and cd is ejected immediately
This is already a mechanical problem on dvd drive. Try upgrading optical dvd drive firmware from Dell's support website. Then, download and install IMG BURN. Run img burn. The software will perform a test. If the problem persists, have your optical dvd drive replaced.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | Dell Studio 1537 Laptop
Everyday way of ejecting cd and dvd on dell studio laptop
Most CD drives have a hole underneath the tray mechanism. Using a straightened out paper clip. push into that hole (about 1" at the most) and you should activate the manual mechanism for ejecting.
Aug 23, 2010 | Dell Studio 15 Laptop
All the buttons work. the dvd will not eject manually. i can hear the eject motor turning
You can try to go to "my computer" and right click the dvd drive, then select "eject". If this does not work, reboot and try again. If this still does not work, there should be a small hole near the eject button.Use something like a straightened paper clip and gently push it in.You will feel a slight give, and with a little more push, the dvd tray will open. You should not have to insert it very far; don't push a long item in as you can damage the mechanism, as well as your DVD.
Aug 12, 2010 | Dell Studio 1737 Laptop
I placed a DVD in laptop and now I am unable to remove it as the drive won't open. I can't play the DVD and it appears the F drive has vanished. How can I eject the DVD without causing more damage?
The DVD will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Oct 22, 2009 | Acer Aspire 5920-6727 Notebook
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Cd drive will not eject or run any software
Place your laptop on a flat surface always. It give some tilt on already cramp space on the cd drive.It could make disc hit something inside to make it stuck so it will not spin and read. It also misaligned mechanism inside the drive to make a full eject.
Apr 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
May 30, 2007 | LaCie (300987U) DVD RW Dual Layer Burner
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
