Question about Smeg 36-Inch Flat Design Wall Mount Ventilation Hood
Smeg extractor not working
Bulb went then utterly stooped working have checked fuse
SMEG Microwave FME 20EX3 - light bulb has blown but unable to find where it is to replace it
my panasonic light went out and Panasonic support told me I had to take it to a service center to get it replaced - ARE U KIDDING ME!!!!
Well it required taking the cabinet totally off to get at it. Just watch where u put ur fingers. The big capacitor holds a charge for a long time.
Sep 14, 2015 | Smeg Microwave Ovens
How do I locate the fuse for Smeg oven sa9066xng?
The fuse is in the mains plug......but if you have the clock it won't be the fuse! The bulb has blown......replace bulb!
Nov 09, 2014 | Ovens
Smeg extractor
Is their power to th eoutlet that you plugged it into?
www.smeguk.com/user-manuals
Sep 07, 2014 | Televison & Video
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Radio stooped working. I bought a new one and it wont work either. I thought I checked to fuses. What fuse powers the radio?
Check all of your fuses. Today's radios require two power sources to work. One constant (to retain memory) and one switched.
Apr 11, 2011 | Car Audio & Video
Please could you advise how to change the light bulbs on smeg extractor fan KD70x-1. They seem to be in sealed units, and I cannot get at them from behind when I take the filters out. Thanks!
Had the same problem, eventually figured out that that they just pull down from the outside. You need pretty strong finger nails to start pulling them out at the outer edge of the circle (not the inner circle of teh bulb area, you could use a thin screw driver but then you may scratch your s/teel. Once out look at where the wire goes in and you will see a litle black clip pull this out towards the outside and pull the bulb holder out, you will have to pull the wires initially , then pull out the bulb and replace
Oct 10, 2009 | Kitchen Ranges
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Smeg 36-Inch Flat Design Wall Mount Ventilation Hood Logo
63 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
