Question about Toshiba 26AV500U 26 in. LCD HDTV
TOSHIBA POWER SUPPLY PROBLEM
POWEER SUPPLY PROBLEM
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
What is the problem you faces with this TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 24, 2014
  • MIKE SELLERS
    MIKE SELLERS Mar 24, 2014
    TV HAS A WHITE SCREEN BUT WITH AUDIO CAN CHANGE CHANNEL JUST CAN'T SEE ANYTHING AT ALL ON SCREEN
Toshiba satelite laptop won't poweer up, built in battery.
Built in battery? Why? Did someone glue it in place?
Those batteries are found on the bottom of the Laptop and are easy to replace. You can get them fairly cheap (like $40)
Here's and extended life 95w battery from Amazon
Amazon com Toshiba Satellite A665 S6086 Laptop Battery 95Wh 8800mAh...
Aug 08, 2016 | Toshiba Satellite A665-S6086 Laptop
MY SCREEN TURNED BLACK
Is this a power cut off or a blank. If poweer is not present then the supply voltage to the circuits must be studied and rectified.
however if the volages arre present then it can be failure of the display processor/drives.
Sep 25, 2010 | LG Televison & Video
My tv will not turn on the green poweer light comes on then goes out
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck
Aug 16, 2010 | Philips Televison & Video
Since a recent power failure the printer will not turn on.
It is possible that the power supply in the printer has failed. You will need to open the power supply unit whichcis within the printer. Open the panels and get acess to the power supply which is a SMPS- switch mode poweer supply. Start from the fuse, the surge protector which could be short or the mains rectifier, mains capaccitor or the SM driver. Replace and proceed.Check for short inthe secondary side for fusible resisistors opening, for diode shorting or zener shorting. Also check for the optocoupler which feedsback the switch. Use a good multimeter to check. If you are not familiar ask a friend with electonics knowledge to help. However if you visibly notice a fault of a burnout replace and proceed. hope this helps. Good day
Jul 02, 2010 | Canon PIXMA MP510 All-In-One InkJet...
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
Not getting power on my t2882 e-machine.
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Mar 19, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
My sony Vaio will not turn on, i tried removing the battery but still it will not boot up
Did you try to do a POWER DRAIN
1. Remove the power supply and Battary
2. Hold the power tab for 45 seconds
3. Plug your PC into the power supply and try to poweer on
Jan 21, 2009 | Computers & Internet
HP Desktop power up problem
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
Oct 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Toshiba 26AV500U 26 in. LCD HDTV Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
