Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Squeeking drive belt
Belt drive belt squeaks
2006 Nissan Sentra. Belts squeaks and stop seeking when you step on brakes.
If I understand this, your fan and other belts driving components in the engine bay stop squeaking when stepping on the brake? Your belts may need some adjustment to tighten. But it may be a vacuum hose leaking around the power brake chamber, or it is leaking, and sounds like the squeeking you describe. I would temporarily confirm the belt squeak by using a "Belt dressing spray" from your auto parts store, to see if it really is the belt or a possible vacuum leak. My belts squeak sometimes after the first start of the day in cold weather since the alternator is working very hard to recharge the battery after the start. It will be quieter when the engine is slowed down as in your braking scenario.
Mar 24, 2015 | Nissan Cars & Trucks
How do you lube the deck belt
use a good silicon spray. it goes under the belt between the belt and walking deck. apply in a "s " pattern to cover entire area of walking belt.this keeps the friction down and squeaking noises
Apr 16, 2014 | Reebok Exercise & Fitness
97 plymouth vourger new belt still squeeks
It sounds like one of your pulleys may be having bearing issues, one way to check this is to go to the parts store and buy some "belt dressing" it is a spray that stops belt squeak. Find a safe spot where you can spray the belt while its moving and only spray the belt. If the belt stops squeaking its just a squeaky belt. If it keeps squeaking then you may have one of your pulleys going bad.
Sometimes pulleys will squeak too if they are just not very lubricated. If the belt dressing works you are good to go, if it doesn't work, go ahead and give the belt area a good spray down avoiding your electrical components. Thanks.
Mar 20, 2011 | Plymouth Grand Voyager Cars & Trucks
I have a squeak when my washer is in the rinse mode , is there a belt on my model
There are springs that keep the tub in balance that could squeek, but no belts. The whirlpool brand top load washers are all direct drive, which means that use a motor coupling instead of a belt.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 02, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool model LEQ8800 - squeeks when running, periodic in nature (1 squeek per revolution), sort of like a high pitched chirp; louder and longer when fully loaded. Is this a bearing (that needs to be...
he belt tensioner has a roller with a bearing in the middle of it. that is your squeaking problem on every revolution it turns
replace the roller and belt sold as a kit at SEARS
Jun 10, 2010 | Dryers
When I turn on my 2004 infinity g35, it squeaks loud for few seconds, a noise comparable to a loud hiss
There may be debris in your drive belt causing a squeek. With the engine running pour some water on each belt, this will cause the belt at fault to squeek.
Feb 02, 2010 | 2004 Infiniti G35 Sport Coupe
2000 model chevy 3500 5.7 350
try changing the belt it might be squeeking it self or you did not replace the right part that was squeeking or another part was squeeking alnog with the idler
Jan 06, 2010 | 2000 Chevrolet Silverado
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Squeaking belt ?
If changing the belts didn't stop the problem, it may be a pulley that is making the squeak, not the belts. When belts age, they tend to form a glaze on the contact surface, which can cause slippage, or squeak, or squeal, also if engine fluids get on the belt due to leaks or spillage, it can cause a problem. If you feel it's definitely the belt(s) making the noise, check the belt tensioner for wear. There is usually an indicator (stamped on the tensioner) that shows if it is in need of replacement. If that's the case, it would not keep the belt(s) tight, and could cause them to slip and squeal. Let me know what you find, or if you have further questions. Curt
Apr 17, 2009 | 2002 Nissan Pathfinder
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
