Question about Motorola Xpr6550 Vhf 136-174mhz 160 Channel
How do i return xpr6550 motorola back to factory settings
Radios won't connect
  • Motorola Master
  • 1,654 Answers
The radio would need to be reprogrammed by an authorized Motorola dealer with the appropriate proprietary Motorola software subscription.
Best regards.
Posted on Mar 24, 2014
How do i return xpr6550 back to factory settings
This would be something only your dealer could perform, or someone with the Motorola proprietary software and cable.
Mar 23, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
I need to crack the password in a Motorola XPR6550
Typically this can only be done by the factory, or by the dealer who originally programmed the unit.
Best regards.
Mar 18, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
No display
First check your battery. When a battery is bad or low it can cause various items to fail including loss of transmit and LED screens going dark. If the battery doesn't seem to be the problem, your radio is in need of repair.
Feb 08, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
Xpr 6550 no mic audio
Be sure the level is set correctly in the CPS software for your codeplug.
Jan 22, 2014 | Motorola Xpr6550 Vhf 136-174mhz 160...
Impress battery charger blinks green and red
My Impress battery charger has a sticker on the bottom of it showing that flashing green/red means that it's about time to replace my battery.
Mar 15, 2013 | Motorola 1571477l01 Contact Dust Cover...
My Motorola Radius CP200 has lost all channels that was set by dealer is there a way to reset back to factory settings?
It is seldom a CP200 loses frequencies/PL code settings. It is more likely the radio has a bad battery or another issue. The only way to reprogram the radio is by taking it back to a Motorola dealer, as they are all dealer programmable only. Sorry.
Best regards.
Dec 18, 2011 | Radio Communications
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
Cant reset my motorola talkabout t5000
Constant static can be a sign of a bad or low battery. If the battery is known to be good, try the radios outside the factory setting to see if the problem persists. If you have no problem when you are away from the machinery, you may need to set your interference eliminator code to a number other than zero. This will turn your eliminator ON, which will block out the radio frequency interference caused by the machines.
If the problem persists outside of the factory, then you should try replacing the batteries. OR possibly just cleaning the battery contacts with a pencil eraser.
The method you are using for resetting the radio will take the radio back to the factory default settings. It will not solve the problems listed above. It will only reset the frequency and code back to the original settings.
Aug 07, 2009 | Motorola TalkAbout T5000 2-Way Radio
Motorola Xpr6550 Vhf 136-174mhz 160 Channel Logo
196 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
