Question about Baby Lock Sewing Machines
BabyLock Decorators Choice I think the timing is off
It sews fine then after a few a minutes or sew it starts to sound chunky. I was told that it might be the timing does anyone know how I can fix it? I just can't afford to pay $120 right now. Which is what the dealer chargers to do tune up on it.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Baby Lock Expert
  • 300 Answers
The timing does not go out on the Decorators Choice (aka Brother NX450).
It is more than likely the needle bar, the crank, or the cradle seizing. Not much you can do yourself, and if you continue using it you will damage those parts... the repair bill will then be much higher.
Posted on May 15, 2014
  • 53 Answers
SOURCE: Sewing patiala salwar
Hi Tamanna,
Sorry i dont know how to sew but i can give you a link sewing.about.com is were you can find help on how to sewing patiala salwar it`s got lots of tips on sewing i hope this is helpful to you.
Posted on Jan 17, 2008
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
SOURCE: singer merritt 8834 sewing machine slows then stops
Did you ever get your sewing machine to speed back up...mine does the same thing Singer Quantaum 5430, runs great for about one minute and then so slow I can't run it any longer
Posted on Aug 14, 2009
  • 371 Answers
SOURCE: My model 120 Husqvarna Viking sewing machine will
Repair manuals are available only to Husqvarna Viking authorized dealers. However, I have seen some on ebay from time to time. Sounds like your problem could be several things - binding of the internal drive shaft which may have a build up of grease and lint which unbinds as you sew, could be a faulty motor, or faulty transformer. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Posted on Jul 30, 2010
I am looking for a Manual for my BabyLock surger blse300. any one have one?
eed Operators manual for Babylock Serger Model BLSE300
https://groups.google.com/d/topic/alt.sewing/7YWkjbKnNjQ
Nov 3, 2005 - I lost my operators manual for my Babylock Special Edition serger. Can anyone tell me where to find one I can look at on the web or purchase?
Need Operators manual for Babylock Serger Model BLSE300
https://groups.google.com/d/msg/alt.sewing/.../FuJ-Xd0dvhMJ
I lost my operators manual for my Babylock Special Edition serger. Can anyone tell me where to find one I can look at on the web or purchase? Thanks in ...
Babylock BLSE300 Sewing Machine Parts
www.sewingpartsonline.com/babylock-blse300-serger-overlock-parts.aspx
These parts and accessories are guaranteed to fit your Babylock BLSE300 ...Instruction Manual, Babylock BLSE300 ... Serger Needles, Schmetz DCX1 (5pk).
Baby Lock - FAQ (Frequently Asked Questions)
babylock.com/support/FAQ/?FAQ=10
Jan 12, 2016 | Sewing Machines
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
How to replace a lower looper on my babylock bl4-428d serger
Yes, but it's not a do it yourself job for most people, as the timing will have to be redone.
May 16, 2014 | Sewing Machines
Baby lock decorators choice model-error code F01
check with babylock customer service about the code
Mar 12, 2014 | Baby Lock Sewing Machines
Babylock bl5260
it would be a good idea to have the serger checked
Nov 15, 2013 | Sewing Machines
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
May 09, 2010 | Baby Lock Evolve
Do i need to oil my baby lock sewing machine?? Quiter's choice.
I cannot find a manual for this machine except at sew4less.com and the price is $14.95.
Contact Babylock to see if they will provide you with a download of the manual - http://www.babylock.com/contact-us/index.asp
If this is a mechanical machine, use sewing machine oil and the shuttle may be the only place it will need to be oil.
Apr 30, 2010 | Baby Lock BL1556
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Jul 13, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
70 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
