Question about Wolff Sunquest Pro 24RS 220 Volts
I have a Sunquest pro 24rs with the dial 20min timer..I set it for twenty minutes, get in and in about after 5 minutes the bed shuts off the timer is still going and fanis still running but the bulbs
Bed bulbs shut off after getting in and tanning bed timer still running, why?
3 Suggested Answers
SOURCE: Where do I find replacement trim profile for my Sunquest Pro 16 SE tanning bed
Ebay has several:http://compare.ebay.com/like/350311266168?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Mar 02, 2012
SOURCE: My Sunquest, Pro 24RS.
ballast is about the only thing left its hard to check anything electrical without a volt meter it could also be the bulb holder
Posted on Feb 09, 2013
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
I lost my tanning bed hinges to my sun quest pro 24 rs.
You are better off buying new hinges. Call manufacturer.
Sep 21, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
Sep 18, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring home tanning bed
If you are installing a bed in your home for the first time, you should have a trained technician to do it, or bad results can happen. Be sure the voltage is correct to the bed - very important. All local wiring codes should be followed for safety - you don't want to kill anyone or the bed.
Sep 02, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wolff Sunquest Pro 24RS 220 Volts Logo
74 people viewed this question
Top Wolff Health & Beauty Experts
Steve
noel
noel
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
