Need pin which is not on router to conmect - Computers & Internet
  • 52 Answers
What brand of router and there is always a way to get into the router by LAN cable and when you login you will see the PIN, after that you can dissable PIN and use password
Posted on Mar 25, 2014
Ford transit conmect wont start
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here:http://www.xcardiag.com/
Jun 17, 2014 | Cars & Trucks
Hi, I got a tp-link 8901g, but no pin code exists behind the router. Only there is a P/N on its pocket with 10 digits, while I need a 8-digit pin for configure my wireless network. What should I...
If you are configuring your wireless network for the first time there should be no pin required, if there is it should be listed in the manual of the device. If you received this router second hand then you will most likely need to perform a factory reset on it to remove any passwords the previous owner may have set. The default login to the router to access all of the router configuration is user: admin password: admin. To factory reset the router you need to hold the reset button with a pin/paper clip while powering the device on and continue holding it for 15 seconds after powering it back on. This should wipe out all configuration and let you back to stock parameters where you can access the router at 192.168.1.1 and use admin/admin to access and reconfigure your wireless settings from scratch.
Oct 13, 2013 | Computers & Internet
Steering wheel radio control not working
You most likely have a defective Combination switch (Also known as "Spiral Cable" or "Clockspring") The audio system uses pins 14, 18, and 17 of the combination switch to make conmection to the audio system. Pin 17 is the reference voltage in. A failure here, will cause ALL audio controls to malfunction at the same time.
The cruise control uses Pins 19 & 20 of the combination switch....Totally different circuit. Just because this circuit is working, does not mean that the problem is not in the combination switch.
May 18, 2012 | 2006 Nissan Altima
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
Need to find PIN number, resetting wireless connection to laptop
You will get the PIN by accessing the router page. If you want a detailed instructions right-click the title "How to Retrieve Wireless Password or PIN of Linksys Router" .
Nov 14, 2010 | Linksys Wireless-G WRT54G Router
I need to no my 8 diget pin on my belkin router and it is not on the router
Are you trying to connect to the wireless network
on a WINDOWS VISTA / 7 computer? Sometimes on the
windows vista computer , it will ask you for the
PIN number when you try to connect to the wireless
network. On the same window at the bottom you will
find the option " I want to connect to the network
or I want to enter the key manually". If you click
on that option , it will ask you for the security
key.
If you don't know the security key, then you will
need to check the settings of the router. You will
need to open the router set up page where you can
check all the wireless settings of teh router. If
you want, you can also find the PIN on the
wireless settings page of the router.
If you are trying to connect any other wireless
device to the network and it is asking you for the
PIN then you will need to open the set up page of
the router and under wireless settings you will
find PIN.
Click here for step by step instructions
Mar 07, 2010 | Belkin (F5D7230-4) Router (587009)
I need a pin for my netgear router, so that i can connect my nintendo wii
From a computer that is connected to the NetGear router,
access the router's web-interface, and set a PIN.
Then, you can use that PIN on your WII.
Nov 09, 2009 | NetGear DG834G Router
I have a wireless laptop and my new router wants a pin number before ir conects were can i find the pin number my router is a linksys g wireless adsl2+gateway
pin number or password. the password for the router for administration is admin and admin.... for security you may wish to change them. the pin number is likely for connecting to a secure network. it may actually be on a label on your router or you need to sign into your router to obtain it. first you need to hook into the router with a network cable from your computer to the router. open a web browser and type 192.168.1.1 the hopefully the default password wasn't changed (or you know it) once you have signed in find the tab for wireless security. your code/pin should be in the second tab of the submenu
Oct 21, 2009 | Belkin (F5D5231-4) Router
Wireless router req. a pin when trying to connect to internet
There is no need for the pin number . If i am not correct you are using Windows vista ,
If you see underneath where its asking for the pin you will see the option like " i dont want to configure this network i just want to connect " OR i dont have pin i want to enter network key or passphrase " you need to click there and it will make you to connect with your router .
Please rate me ..thank you
Jul 06, 2009 | Linksys Wireless-G Broadband Router
Pin number
pin number is never put on the unit. if u need a pin number its in the users manual/set up manual if u never changed the origanl pin upon setup. on the back of the router there should be a reset button pn sized of course which will set it back to manufacturers settings which will then take the origanl manufacturers pin number which is in the setup manual
Apr 29, 2009 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
