Question about Water Heaters
Atwood g6a 8e
Water-heater Atwood G6A-8E Windows When I light it leaves a rather yellow flame and without pressure during a few seconds and it extinguishes and it starts again some times and all has blow the button ON/OFF remains to light water does not heat and exhaust does not function
  • Water Heaters Master
  • 3,368 Answers
The yellow is caused because the flame does not have enough oxygen. Per your explanation that is being caused because the exaust is not working. Fix the exaust problem and it probably will begin opperating properly.
Posted on May 03, 2014
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: atwood rv water heater model G6A-8E heats water to
Normal causes for that would be by-pass valve not in proper position, or defective, allowing cold to mix with hot, or thermostat not touching up against tank properly, or defective. Do you know where that thermostat is?
Look where the black foam cover is, with white letters, below pressure relief valve. One is lettered ECO, other THERM. If you note where the wires go, so as not to mix them up , and pull them off, then peel back the foam cover, you'll see 2 little round discs, that are held against the tank by a small spring. They need to be checked that they are in there properly and are up against the aluminum tank.
Posted on Apr 25, 2010
motor1258
  • 6674 Answers
SOURCE: Have an G6A-8E Atwood water heater. It Starts fine...
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
Posted on May 26, 2010
My atwood g6a-8e takes over a hour to heat up and is only warm can anyone help
Have you checked by-pass at rear of heater to make sure all valves in proper position for normal operation? What type of flame are you getting while heating, is it nice and blue, and not jumping too far off burner and roaring?
Dec 03, 2012 | Water Heaters
I have a 1997 Fleetwood Bounder with an Atwood G6A-8E water heater. My pressure relief valve was leaking heavily, and I think it shorted something out, because now my electric igniter will not light the...
Have you checked your fuses? there should be a removable cover to pull off there will be a fuse in side that powers the self ignite..can you take a pic of the panel and post it or send it to my email?
Nov 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Burner lights but will not shut off. then pressure
CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
113 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
