Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Users manual cratftsman riding mower L2000 need to repair drive belt
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
You need to get down on the ground and have a look at why it is not turning left. Its as simple as that. A repair will not tell why it is not turning left. Good luck.
Posted on Mar 26, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
wadembly
  • 513 Answers
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Posted on Jun 05, 2009
I need a diagram for a John Deere Sabre 1742 riding lawnmower drive belt . Not for the mowern belt, the drive belt .
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Aug 24, 2016 | John Deere Garden
How to replace drive belt on john deere riding mower gt275
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
John Deere GT275 Riding Mower Service Repair Manual
Oct 07, 2015 | John Deere Garden
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
How doyou change the drive belt on a task force 2000 riding lawn mower?
there mite be diagram on deck look in owners manual or to jackssmallengines.com he may have diagram or manual
Aug 26, 2014 | Mtd Drive Belt 42"
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 | Garden
I need a repair manual for a scotts riding mower.drives a few fee
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
330 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
