Question about Polaroid FLM-3232 Television
Polaroid FLM323B Mod. 3200 Dead TV
Dead TV. No picture , audio or back lite. TV has standby power red lite. Hit on button , you get the blue lite.  When the TV is on , you can see some background lines on the upper left quarter of the screen. There is no back lite. You have to unplugged the TV to turn it off. Where can I get parts ?
R. G. Hero
  • 4,102 Answers
Re: Polaroid FLM323B Mod. 3200 Dead TV
I sugest you take this set to a small tv repair shop as these parts can be hard to get if you are confident in repairng it yourself you might find that it is just the starter that has gone these can be replaced but are best left to a trades men if you do want do do it yourself remember you need the right tools you need onr to undo the solder holding the starter in and you will need a fine soldering iron for soldering the new one back but remember the set is still live for 24 to 36 hours after it has been unplugged from the mains this is ttricky to replace and it shouldnt cost much more on top of the price of the part for someoe else to do it at least if they do it and get it wrong they will have to put it right for you just remember to get the price first before they do the work else they will start addind prices on top i had a similar telly with the same problem and it cost me 35 puond to get it fixed this was a lot cheaper than buying a new set so take it to repair shop and they will get you the part and if needed fit it for you but it probably is the starter if its the screen you will be better of buying new telly hope this is some help but you can deffinately buy the parts might have to order them though could take few day.................
Posted on Oct 30, 2007
0 characters
3 Points
Tv has power, but no picture
I hit the button on the sidea and it went to channel 17 I got it back to channe 3 but it still says no signa I do not have a Polaroid remote
Sep 27, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
Tv wont turn on, but have light on fornt of lcd tv? How do I get the power bac on? Has a red light. TV should have blue light when tv is turned on. The light stays red. Why wont it come back on with the...
You are only have 5v standby circuit working, the problem can be in the main control board (not sending signal to turn on the main power supply sections) or the main power supply sections are bad.
Nov 05, 2009 | Polaroid 3211TLXB 32 in. LCD Television
My television screen went black, but there is has sound
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Aug 15, 2009 | Flat Panel Televisions
Polaroid tv w/ black screen
hi..then there is a problem in your smps
power supply.If you have the warrenty period
take it immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Polaroid FLM-3732 Television
Polaroid LCD TV Model 3200 - Will not turn on
you have a power supply problem.. I have fixed serveral tvs with this problem. normally you have to replace busted capacitors in the power supply board.
Nov 10, 2008 | Polaroid FLM-3232 Television
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
Polaroid FLM-3232 Television Logo
359 people viewed this question
Top Polaroid Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Flat Panel Television Expert? Answer questions, earn points and help others
