Question about Razor E300 Scooter
Razor E300 runs but will not move
The Razor E300 ran for about 20 minutes but now it runs but does not engage or move.
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
My e300 razor run but will not move
Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
Aug 12, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Razor E300 runs but very slowly
get some new batteries.
yours are worn out.
Mar 29, 2013 | Razor E300 Scooter
Clucking sound when riding
Neil, I do not have a solution, but however have the same exact problem. Son got an E300 for Christmas. My daughter also received an E200. The E200 works fine, but the E300 makes a clunking noise when the throttle is engaged. Also the E200 can make it easily up the drive way, but the larger and more powerful E300 can not. Any help with this would be greatly appreciated. Thanks, Ron - ronsmith@komcepts.com
Dec 25, 2010 | Razor E300 Scooter
Need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
May 14, 2010 | Razor E300 Scooter
Razor E300 Scooter Logo
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
