Question about AEG Washing Machines
How I can test the 124304203 analog pressure sensor?
Some times it finish the cicle and sometimes no, and My wife find the red LED Start/Pause. I tried to change the pressure on/off sensor, the NTC temperature sensor, the door lock block. The brushes are ok... so it need to check the analogic pressure sensor (How to do?) and the Main board :-(.
Noggin
  • 944 Answers
SOURCE: setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Posted on Mar 13, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 197 Answers
SOURCE: Indesit WIA 121 washing machine,
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Posted on May 17, 2009
Oil light wont go off
oil sender or you actually have no oil pressure.
Nov 12, 2017 | Cars & Trucks
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
May 05, 2015 | AEG Washing Machines
What means the code error F26?
F26 Boiling protection. The program is interrupted and the drain pump is operated. The display shows Technical fault F26. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
Temperature at NTC temperature sensor has exceeded 194?F (90C).
Remedy:
Check the heater relay and replace it if necessary.
Cause:
NTC temperature sensor providing inaccurate information.
Remedy:
Replace the NTC temperature sensor.
Cause:
Heater relay closed.
Remedy:
Replace the heater relay.
Aug 25, 2014 | Dishwashers
Lamp wont ignite.lamp light red flashing.
Before changing lamp use a canister of compressed air to remove dust specially inside the projector when lamp is away.
Dec 13, 2013 | BenQ PE7800 Multimedia Projector
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Washing machine doesn't stop after time allocated
Possible suspect of the inlet flow, the pressure sensor or the program controller.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Mar 08, 2013 | Washing Machines
Flashing light 6 times, whirlpool dishwasher ADP4501
I had the same problem with a Whirlpool ADP 6515, led flashes 6 times, pause and repeat.
Open the door, remove the 2 screws that hold the control panel (1 top left, 1 top right). Gently lift the control panel up and away from the door to reveal the wiring, controllers etc. My controller was a Flextronics UCB-IC-EBL-P7-M3-HE1. Look at the connectors, one of them is marked on the controller as NTC and has 2 blue wires, push down on the white plastic tab below it and disconnect it (pull it horizontally away from the controller)..
I used a multimeter on 200k range and measured the resistance by probing those 2 blue wires and the NTC temperature sensor measured about 50k ohms +/- 5k depending on the room temperature. And that is correct for that NTC. (I knew the NTC was good as I had removed it from underneath the machine previously and measured the resistance whilst holding it under the hot tap as it went from cold water to hot. It's a Negative Temperature Coefficient sensor so the resistance reduces as it gets hotter).
So problem was definitely not that.
Solution was simple, on the connector itself, just use a very small flat bladed watchmakers type screwdriver to clean the pin contact faces and then gently pinch the pins of each wire closer together so that they bites tighter onto the controller.when you reconnect it.
Refit the control panel and problem solved.
Conclusion; the contact resistance of the connector to the controller added to the total resistance of the NTC and made the dishwasher think that the water was below the safe activation of the motor cycle, e.g. it thought the water was iced up.
Job done !
Apr 25, 2012 | Whirlpool Dishwashers
I am getting a Sud code and then an F35 error on my Maytag frontload washing machine. I have unplugged it...to reset and sometimes it works. Other times it doesn't. How can I fix it?
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.
Jul 31, 2011 | Maytag Washing Machines
I DO NOT HAVE A MANUAL, WHAT DOES THE MESSAGE F 35 MEANS? IS CONSTANTLY BLINKING AND THE WASHER WILL NOT START IT JUST KEEP RELEASING THE WATER FROM THE HOSE ON AND OFF, EVERY TIME I SELECT ANY CICLE AND...
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Please post back in case of further assistance. Hope this helps...
Daniel
Mar 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
75 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
