Question about Ames 225ft. ReelEasy Hose Reel Cart 2386275
Purchased a hose reel cart and need a bolt replaced
I need one (item A) on hardware list (M6x 15) replaced (bad thread)
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Rankam
You can get 10" never flat tires with 5/8" hubs that will work. Home Depot has 4 for $59 online.
May 12, 2014 | Ames 225ft. ReelEasy Hose Reel Cart...
Need 4 allenhead bolts (2 3/8 inch) and 15 nylon washers for Chatham Lifestyle Crib. Customer Service states they no longer carry the hardware for it.
Do the bolts have to be allen head (hexhead) bolts, hardware store and match the threads and the length of bolt and switch to say, a phillips or flat head style bolt. Did the CSR at the hardware store NOT try to help you in this way?
Jan 02, 2013 | Baby Gear
How do you get fan blade loose from water pump on 1998 f-150 4.2 liter
I seem to recall it is a left hand thread. They make tools for removal.
The wrench I think is a 32 mm open end looking wrench and the part to hold the water pump is a spanner wrench that is hooked shape for holding the bolts. Not sure on the size, could be a 35 mm nut on there...
The wrench for the fan blade
Spanner to grab and hold the water pump bolts.
Saw 1 person used a piece of flat stock steel, drill the holes at the same place as the bolts on the water pump, and install longer bolts through the flat stock to hold the water pump. He used a thread finder to get the correct size, and length of the factory bolts. They are a metric thread pitch, I cannot recall what they are at the moment ( M6x 0.75 is ringing a bell, but I can only be 50% sure about that )
The flat stock was used in place of the spanner to hold the water pump, and that person just used a 14" pipe wrench to grab the nut on the fan.
Aug 06, 2011 | 1998 Ford F150 Regular Cab
Harmonic balance pulley traveles 180 degrees and makes a knocking noise center bolton crank does not rotate when this is moved by hand , whats up? 1995 buick park ave.
The outer ring should not move independently of the inner pat of the pulley. If it does the rubber isolator in between the two parts is bad and the pulley will need to be replaced. The pulleys are common to fail and you can usually get them from your local parts store or a gm dealer. The center bolt should be a 15/16" . You may need an impact wrench to remove. There will be a couple of threaded holes in the pulley. You will need a pulled and bolts to remove the pulley. A steering wheel pulled works really good for this and you can find the bolts at your local hardware store. I'm pretty sure they are 6mm holes but I do not remember the thread pitch. It's a pretty simple job and the worst part will be getting the crank bolt loose.
Jul 14, 2011 | 1995 Buick Park Avenue
Can't figure out the bolt size for blade shaft. need replacement bolt
Peter, without a complete model number, no one will be able to provide an owner's manual and parts list which would provide the bolt size either. So let's try to figure out the best way to determine a replacement for your fan.
If you can locate the model number of your fan, you can easily obtain a parts list for your fan and the replacement blade retaining bolt.
If that's not possible, the next best thing to do is take the fan with you to a local hardware store (or a big box Home Depot or Lowe's, etc.) and try to find the proper sized bolt in their hardware isle. Many hardware stores have loose bolts that you can try and find the correct thread size and length to fit the fan shaft.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Rival Dryers
Philips PSU board Repair or Replace?
Search results for LJ44-00101C 1 Item
(hiding 1 out of stock) Show 5 10 15 20 25 50 100 200 per page View as: List Grid Show all items Sort by Relevance Name Price sort_desc_arrow.gif file_1_5.jpg Samsung LJ44-00101B Power Supply Item #: LJ44-00101B $ 157.95 Add to Cart Learn More | Add to Compare
1 Item
Aug 10, 2009 | Televison & Video
I've striped the threads on the blade bolt of my 15 y/o Craftsman tablesaw. Can that be replaced?
Best repair would be to get a replacement shaft from Sears. Another option there is an item called a threaded shaft collar. It is made of one piece, split thru the OD to the ID on one side. A screw is adjusted to tighten the collar against the shaft. Flats could be added to the OD and the collar could be used in place of your current nut. This item could be purchased from an Industral Supply store. 2nd option - An experence welder could add material to the threaded area and the shaft could be rethreaded
Jun 24, 2009 | Craftsman 10" Table Saw
I need a diagram of the entire breaking system on a 1993 ford taurus i just replaced a rear line and i think i stripped the extention piece i had to add to the end of the break line. the one that goes into...
here is a 96 taurus
Item Part Number Description 1 2C296 Anti-Lock Brake Tube 2 2C219 Anti-Lock Brake Module 3 2005 Power Brake Booster 4 2263 Front Brake Tube 5 2B091 Brake Pressure Control Valve 6 2140 Brake Master Cylinder 7 2B547 Brake Load Sensor Proportioning Valve 8 N802191-S60 Bolt 9 2L568 RH Rear Brake Tube 10 2L569 LH Rear Brake Tube 11 2C287 Brake Fluid Distributor Tube 12 N808531-S301 Bolt 13 — Front Side Member 14 N802324-S56 Bolt 15 18124 Front Shock Absorber 16 2B121 Front Disc Brake Caliper 17 2078 Front Brake Hose 18 2264 Front Brake Tube 19 2553 Rear Disc Brake Caliper 20 2A442 Rear Wheel Brake Hose 21 N808728-S60 Bolt 22 — Side Rail 23 N802324-S60 Bolt
Item Part Number Description 1 2B547 Brake Load Sensor Proportioning Valve 2 — Body 3 N802191-S56 Bolt (2 Req'd) 4 2L568 Brake Tube Assy 5 2L569 Brake Tube Assy 6 2265 Brake Tube Assy 7 2B255 Brake Tube Assy 8 5500 Rear Suspension Arm and Bushing 9 W611634-S301 Bolt A — Tighten to 11.4-15.6 Nm
(8-12 Lb-Ft) B — Tighten to 10-14 Nm (7-10 Lb-Ft)
Brake Hose, Rear —Drum
Item Part Number Description 1 — Rear Side Rail 2 2L569 Rear Brake Tube 3 N602324-S60 Screw 4 N611193-S60 Screw 5 2C023 Left Hand Rear Hose and Connector 6 2210 Rear Drum Brake Backing Plate 7 18125 Rear Shock Absorber 8 2267 Rear Brake Tube A — Tighten to 16-20 Nm (12-15 Lb-Ft)
May 10, 2009 | 1993 Ford Taurus
Ames 225ft. ReelEasy Hose Reel Cart 2386275 Logo
Top Ames Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ames Garden Expert? Answer questions, earn points and help others
