Question about Philips AJL308 USB/SD radio alarm clock
Can we download one of our own picture permenantly on the AJL308
Can we download one of our own picture to replace permenantly the supplied picture of those two persons eating a lollypop,without having to leave the memory card of our camera inside the AJL308?
    Problem Solver:
  • 9 Answers
No dont try it will crash the whole thing
Posted on Nov 14, 2009
Need a user manual
philips.com has user manual and other info for this unit
Nov 26, 2011 | Philips AJL308 USB/SD radio alarm clock
I have a samsung u450, I am trying to reset my phone back to its factory settings. How do I go about doing that?
WARNING: Restoring the handset will permenently Delete All Data, including Contacts
Note: All locked pictures, videos, ringtones, music, sounds and downloaded content will be permenently deleted when restoring the handset to the default settings.
To restore the handset to the factory default settings follow the steps below:
  1. While in standby mode, press OK for Menu
  2. Select Settings & Tools (9)
  3. Select Phone Settings (6)
  4. Select Security (9)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed, then press OK
  6. Select Restore Phone (5)
  7. Highlight Yes, using the navigation keys
  8. Press OK to confirm resetting the handset
  9. Press OK at the re-program the phone screen
  10. Enter the lock code again, default password is the last 4 digits of cell phone number, unless it has been changed
  11. Press OK to confirm restoring the handset to the factory default settings
Note: Press *228 and SEND after the power cycle to re-program the phone
Hope this was helpful?
Jan 23, 2011 | Samsung SCH-U450 Cell Phone
How to I disassemble a philips ajl308/37? I removed all the screws but it still will not come apart. The display keeps flickering and eventually it just goes black and won't come back up.
My unit did the same thing. Did you remove the 2 white rubber pads on the top at the back. There are 5 screws total. If so you then have to use a smaal flat screw driver on the sides to get the cover to unlock from the back There is also some double stick tape that holds the 2 halves together so its a little tricky.
May 20, 2010 | Philips AJL308 USB/SD radio alarm clock
Electric schematic
did you ever find the schematic for the AJL308?
Apr 23, 2010 | Philips AJL308 USB/SD radio alarm clock
My LT37HVS 37 in. tv clicks constantly when plugged in.
The main power supply is probably failing, or there is a failure on one of the boards that is causing the power supply to go in to protection mode. Most of the time this type of fault comes from the power supply. It is very possible that a number of the electrolytic capacitors on the power supply board are failing. It is also possible that there are other types of component failures.
Most technicians will not service the supply at all. They will replace the power supply board, as like any of the boards in this type of TV technology.
Jerry G.
Feb 03, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have a Ripspeed DVD-730B head unit for my car. its all installed but when trying to play a dvd it displays a message sayin: do not watch while driving and then only plays sound, no picture. how do i...
if the unit was installed with a handbrake lead properly it will only get picture with handbrake on,try taking that wire off and connect it to a permenant positive like the permanent live to the head unit,so the unit thinks the handbrake is on, or if it wasnt installed properly and that wire is somewhere else like a permenant negative then the unit thinks the handbrake is always off hence no picture while driving,hope this helps :-)
Mar 13, 2008 | Televison & Video
Philips AJL308 USB/SD radio alarm clock Logo
566 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
