Question about Toshiba Regza 52XV645U LCD TV
Change firmware to force digital
Set reception default to digital
    Top Expert:
  • Toshiba Master
  • 74,198 Answers
It is a skilled work. Will be best to contact any experienced service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 24, 2014
How do you set an atomic clock
You're not supposed to set the time -- it's supposed to synchronize with the US atomic clock broadcast automatically. Perhaps putting it in a different area of the house, or turning it to a different orientation will help it make the initial connection.
If it still won't, here are instructions from one of the LaCrosse models... use them or go to http://www.lacrossetechnology.com/clocks/atomic-digital/wall/
and find your particular clock, then download the instructions.
MANUAL TIME SETTING
In case the atomic clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock. Note: In 12 hours mode the time will be displayed with an additional "PM" for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1.
2. Set the desired hours by pressing and releasing the + key followed by pressing the SET key.
3. Now the minute digits will start flashing.
4. Set the desired minutes by pressing and releasing the + key . If the + key is held, the units will increase by 5.
5. Press and release the SET key to move to the "Year Setting".
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the next hour.
WWVB reception occurs daily at 12:00 am and 06:00 am. If the reception is not successful at 12:00 am, then the next reception takes place the next hour and so on until 06:00am, or until the reception is successful. If the reception is not successful at 06:00 am, then the next attempt will take place the next day at 12:00 am.
The other times WWVB reception takes place are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
Jul 28, 2014 | La Crosse LaCrosse Atomic Digital Wall...
Our Konica Minolta BIZ HUB C10 message in window is MEM.RX. Can you explain what this means. Thanks
In the Fax/E-mail - Fax Configuration - Reception Operation page, set-
tings for receiving faxes can be specified.Memory RX Mode:
Select whether to allow ("On") memory reception or not
("Off"). In cases when confidential faxes are being
received, the received document can be stored in the
memory and printed at a specified time or when memory
reception is set to "Off". A password can be set to spec-
ify the starting time or ending time of memory reception,
or to cancel the function. The set starting time and end-
ing time are valid every day until memory reception is
turned off.
Choices: On, Off
Default: Off
Configuration Menu Equivalent:
RX SETTING - MEMORY RX MODE
Mar 27, 2011 | Konica Office Equipment & Supplies
Is there a firmware upgrade for the 32dw6834 tv to improve digital signal reception?
this TV Tuner is analog Tuner, dont have any digital tuning, only control and process is digital, so not have any possibility a firmware for tuner, only for boards of control and process video/audio
Nov 22, 2009 | Philips Televison & Video
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Digital tv antenna reception
try googling how to build an antenna with coat hangers. not pretty but cheap!
Apr 08, 2009 | Insignia Digital-to-Analog Converter for...
Different problem
Um double check this set "WEP Encryption" 128 bit
set the "Key Type" to ASCII
type a 13 digit password into key 1 and click Apply
If it is still messing up start over and default the router. Update the firmware and try again. All else fails and no encryption keys will set.Change the name of your SSID and stop broadcasting the SSID or buy a new router maybe sounds like a software issue updating the firmware could correct though.
May 06, 2008 | D-Link DSL-G604T Wireless Router
FM RADIO IS ACTING WEIRD
Replace the headphones, see if reception improves. If that fails to resolve, try reset and recovery. If that still fails, the headphone jack is faulty. Replace.
Mar 29, 2008 | Creative Labs ZEN Vision:M Digital Media...
Nikon coolpix 3700 did not take picture
Nikon has a new firmware to solve this, try change the firmware... the last firmware is the 1.2
Sep 15, 2007 | Nikon Coolpix 3700 Digital Camera
Toshiba Regza 52XV645U LCD TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
