Question about Toshiba Satellite M65-S821 Notebook
Stripes after a while
When I switch on the TV is ok, but after 5 min, start apearing the stripes first like a horizontal barcode in white, after a min change to blue and then a lot of stripes up down. Do you know what can I do or whats the problem?
Thanks
    Problem Solver:
  • 9 Answers
Most likely, colorful stripes on a computer screen is due to a RAM error. These errors may encompass: 1.)incompatible memory installed in your machine, or 2.)mismatched memory modules, or 3.)a memory module that is failing. In any case, I highly recommend bringing your machine into a repair shop. One other likely cause is that maybe your hard drive if failing due to an excess of errors - this may be a prelude to an imminent failure. For RAM, you might want to check the motherboard manufacturer for recommended memory manufacturers and modules, to see if yours is listed and/or compatible. If not, you may wish to replace it. Furthermore, check to see if the numbers and combination of memory modules that you are using is, in fact, supported. If both are compatible, you probably have a failing module. Yeah. I know. A lot of jargon and work; and this probably didn't even help. Last bit of advice: If it's worth it, bring it in for repair. Good luck.
Posted on Jun 15, 2009
What is the problem with a lg plasma tv green stripes 50% of the screen for 10 minutes
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Aug 22, 2014 | LG MZ42PZ10 42 in Plasma TV
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
When I start the TV there are coloured horizontal stripes on the screen. The stripes slowly fade and the screen becomes white/grey. Sometimes there are sound, but I think i managed to find a meny or s
normally there are some fault caps around the video amp try to replace them with new ones since am not sure of the exact faulty cap .its located on the motherboard.
Jan 20, 2013 | Televison & Video
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Sony Trinitron KV27V42. When I turn it on, it has horizontal white stripes across the screen. But when I hook it up to a vcr or a dvd player, I don't see any white stripes. What could be the...
Hello
Check its AC input connection for any loose contact. Check it with pluging it on an other plug point in your home. It is a type of interference, and some electronic and electrical equipments in your home may also cause this trouble when it works. Check these please. OK.
Mar 20, 2011 | Televison & Video
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Striped color distortions on Nokia 300 Xa flat panel
This is power supply problem.
1. First u replaced the power out put capacitors , 6V, 12V, etc.
2. cheak the diodes.
Oct 17, 2008 | Computers & Internet
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Toshiba Satellite M65-S821 Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
