Question about Ovens
Concorde turbo hygena oven grill not turning on. checked fuse box
Worked last night, now will not turn on. Is there a fuse on the oven I need to check/ change
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
SOURCE: Amana gas range bake burner does not heat
AMANA GAS RANGE
MODEL #ARG7301WW P1143323NWW
SERIAL: 9710232146
Hi Tamiw and oh Mighty Guru Text,.
I had the same problem with the oven not emitting a flame from the burner, but at the same time- the ignitor lit up and heated the oven enough to say it is 'HOT'.
It seems to be an intermittent problem';sometimes it emits a flame while other times I would wait 11 minutes with the dial set to 400 to emit flames.,
Detailed description of PROBLEM and steps I have already taken:
The Ignitor always turns on, and lights up.
1. After the initial cleaning of the burner vents with a coarse bristle cleanibng brush, I turned the oven dial on and everything seemed to be working fine. ie: ignitor turned on, blue flames came out of the burner and maintained a constant temperature.
Then,-after I had performed a "self-clean", to see if this feature would now work, it did! I used the oven for bake a few hours later......
The same symptom ocurred, the ignitor went on, but no flames were observed, YES, there was heat coming from the oven, but NO flames coming out of the burner mechanism:
The Ignitor turned on, but no "flames" were observed. Heat was given off from the glowbar, but no flames. I did NOT smell any gas, only what an inside of the oven smells like after cleaning.
From my records, I had replaced the thermostat about 4 years ago.
Today, I tried this again, and sure enough the ignitor lit up, and the burner was emitting blue flames. But when I put the "FLAME SPREADER" back, and turned the oven OFF, then on again to bake cookies, the oven didnt seem to heat up completely.
Could this be intermittent? or Could the flame spreader hamper the burner operation? (Earlier when I loosened the nut on the flame spreader the bolt broke. I tried to replace with another nut, but the bolt/screw was too short for contact.) Could this contribute to the problem? Does the flame spreader need to be tightly screwed for the burner to function correctly?
One thing I am noticing, is that it takes LONGER for the flames to come thru (than the average 90 seconds)
For example: Ten minutes ago I set the dial to 350. 5 minutes went by, and no flames, then set the dial to 450 after ten minutes oven was hot, but no flames?
I THEN SET TIMER FOR ANOTHER 5 MINUTES, AND 1 MINUTE LATER THE FLAMES TURNED ON. Total preheating time for flames to come on today = 11 minutes.
I have a "MULTIMETER" from DIGITEK Model # DS830B+ This should work to see the amperage, but I dont remember how to test it! the MAX OHMs are 2000, MA 200 Max, 500V
http://www.digitek.com.hk/
Can I use this to test the current? How would I do this?
Lastly, HOW DIFFICULT IS IT TO CHANGE OUT THE IGNITOR> Meaning do I have to shut off the gas as well as the power circuit?
Ok, hope this helps.
Thanks again,
Callie T
Posted on Jul 19, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
I have an hygena classic built in oven. The turbo cooking option heats up slightly and the fan works but doesn't get to temperature. The grill and convection oven work fine. Any ideas. The oven is about...
The problem is usually down to the thermostat - sometimes it can be moved and end up touching the grill and burning out - other than that they just wear out after time with the heat.
Have a look here for a spare - its easy to replace if your husband is half competent with fixing things.http://www.espares.co.uk
May 11, 2014 | Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Need a user manual for a Hygena diplomat oven model AHY 3420 any ideas please?
I have a manual for AHY3420, it's a very generic manual which covers different ovens. I am happy to send you a scanned copy if you send me an e-mail address.
I have the same oven and all the symbols have disappeared on the third dial (the one which switches on the oven), so I still haven't worked out which setting does what - I can just about make out a grill symbol, but that's about it. Is there any chance you could tell me what the symbols are on the 3rd dial?
Thanks very much.
Sigrun
Feb 10, 2010 | Ovens
Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Jan 04, 2010 | Ovens
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 | Ovens
Oven doesn't work - but the grill and light does!!
Turn off the breakers then back on. Then open up the panel cover and you may find fuses inside there. Check them with an ohm meter. Next you may have a wire that has come off the control switch or the element. Do either of the upper or lower elements work? Lastly, the t'stat may be bad. Let me know how you do.
Feb 18, 2009 | Ariston Technologies Ovens
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
AEG Oven
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
