Question about JVC Televison & Video
Model 4800 After the TV has been on for more than 4 hours the remote control does not work. Is this common?
    Top Expert:
  • JVC Master
  • 74,383 Answers
No this is not common. The remote control should work all the time, whenever the TV works. Gopakumar Gopalan Google
Posted on Mar 24, 2014
4 Suggested Answers
SOURCE: universal remote control
urc 8810BOO theres no code for this remote can u please help me thank u....
Posted on Aug 11, 2008
  • 4 Answers
SOURCE: Lost manual for 4 in 1Radio shack remote model 15-2114. Need Code
I have the same remote. The thing i found is the back of the remote says 15-2114 but Radio Shack website lists it as 150-2114 or 150-2114A. Hope this helps it worked for me last night, but I think the battery is low or something. Here is the link to all remotes by Radio Shack http://support.radioshack.com/support_video/15787.htm
Posted on Apr 14, 2009
SOURCE: I have just bought a Toshiba 32KV501B TV. The tv
I also brought this tv one day ago I don't have a problem with the remote I have a loud crackling noise coming from the tv even when the sound is off think its going back to currys.
Posted on Jan 03, 2012
Hello i have a one for all universal remote and can not find codes anywhere
Without knowing the specific model number for your remote, try the following procedure. It's the one common to many of the One For All Universal Remote models which enables a code search from a library contained within the remote.
SEARCHING FOR YOUR TV CODE
1. On the remote control, press TV once.
2. Press and hold SETUP until the LED blinks twice, then release SETUP.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off. This means the remote has found the code for your TV.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first. You may have to repeat the procedure in Step 4 several times before your remote finds the code for your TV.
5. To lock in the code, press and hold SETUP until the LED blinks twice, then release SETUP.
6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate device key for the device for which you are searching.
Hope this helps.
Feb 24, 2011 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I need the code for polaroid tv with asda remote control model no:urc20-d1f
I just bought a Polaroid 22 inch LCD DVD Combi,, I struggled for hours trying to find a code online,, and eventually researched that my Polaroid TV is made by Phillips,, I entered a Phillips 4 digit code (0081) and it worked.. I also found this link very helpful,, I used the 4 digit code routine. http://www.rtv.co.uk/remote_codes_for_sky_dig_remote.htm
Oct 14, 2010 | Televison & Video
NEED TO GET RCA UNIVERAL CODE FOR RCU704MSP2N T0 G0 TO A SHARP MODEL 13F/M50
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 25, 2010 | RCA Universal Remote Control
I need to program an RCA universal remote for a Toshiba TV
Ideally I need the exact model number of the RCA remote you are using as these remotes use different 3 or 4 digit codes.
However I have listed the common codes RCA use for Toshiba. You will need to go through them, one by one, until you hit on the one that works for your particular Toshiba TV.
If for some reason these codes do not work - please post up the exact model number of the RCA remote and I will look at it again for you.
1) Common 4 digit codes for Toshiba
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241.
2) Common 3 digit codes for Toshiba
000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283.
Hope this helps. If so a rating is appreciated.
Otherwise please post additional information as requested.
Thanks for using FixYa.
Jan 08, 2010 | RCA Universal Remote Control
Remote control
These remote codes also depend on what the exact make and model of the remote control is that you are using. These remotes can also use 2,3,4 or even 5 digits. The other factor is that some universal remotes will recognise the code for your proscan TV - but others will not depending on how they are programmed.
I will give you the most common 4 digit codes for Proscan and hopefully these work for you. If not please post up further detail on the remote control - exact make and model no. that you are using in order for us to solve the problem.
Common Proscan TV codes:
0000, 0015, 0031, 0107, 0162, 0163,1000, 1008, 1068, 1108, 2010, 2118, 2144, 2205
If this works for you please do rate my answer using the thumbs. If not please provide more detail and I will be happy to respond.
Jan 08, 2010 | Proscan 19LA25Q 19 in. LCD Television
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Need remote control code
you need to use the dvd codes that are given (20695) and program it under auxilary mode.
Oct 13, 2007 | Toshiba MD24FP1 24 in. TV/DVD Combo
Televison & Video Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
