Question about Car Audio & Video
In stall a amplifier to the radio of a 1985 volvo gl
I need a color cercit diagram so i know witch wire goes where and a manual so i under stand how to use the amplifier
  • 637 Answers
Are you connecting to factory radio? If so, use a hi-lo converter and use the speaker wires on rear to convert to RCA. The simplest way to do it.
Posted on Jun 18, 2014
How can i hook these speaker to any radio using the neg and pos wires and witch wire is witch??
Answer to:How can i hook these speaker to any radio using the neg and pos wires and witch wire is witch??
Posted by Kelsey Doddridge on Oct 15, 2017.
With loudspeaker terminals facing you, negative or GND is left, positive or audio signal often marked with 'plus' symbol is right.
Otherwise briefly touch power from a 1.5 V battery, the one which moves the cone forward is the correct polarity.
Plus, if terminals are different sizes, follow Nick Elci's advice.
As for 'speakers to any radio', make sure your radio or amp does not overload and cook from too-low speaker impedance.
What this means is your radio may be rated at minimum 8 ohms or minimum 16 ohms per channel.
If you connect a 4 ohms speaker across this radio your radio's amplifier will probably overheat and fry.
I=V/R ohms law.
Also, never use a lower wattage speaker than what the amplifier is designed to output at maximum volume.
This damages loudspeaker, possibly tearing the diaphragm.
If you need to double the ohms from say 4 to 8 ohms, connect two identical 4 ohm speakers in series or SPK-A pos to SPK-B neg. Then outside terminals are neg and pos at 8 ohms and each one at half the power output.
Oct 15, 2017 | Car Audio & Video
1985 Honda GL1200 Gold Wing Aspencade wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1985 Honda GL1200 Gold Wing Aspencade wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Aug 29, 2012 | 1985 Honda GL 1200 Aspencade Gold Wing
1983 Honda Goldwing GL 1100 radio wiring diagram
1983 Honda Goldwing GL 1100 radio wiring diagram Google Search
Honda GoldWing GL1100 Service Manual
Honda Gold Wing GL1100 Owner Manual
Jun 18, 2012 | 1983 Honda GL 1100 Gold Wing
2005 dodge stratus radio wire diagram
2005 Dodge Stratus with Infinity Radio Wire Harness Colors
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Dimmer Wire: Orange/Brown
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: Dark Green/Red
Car Radio Amplifier Location: Amplifier is Mounted Under the Front Passenger Seat
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Violet
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 08, 2012 | 2005 Dodge Stratus
Radio wire colors
1994 Volvo 940 Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Illumination Wire: Light Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Gray/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/Brown
Left Rear Speaker Negative Wire (-): Yellow/Green
Right Rear Speaker Positive Wire (+): Green/Brown
Right Rear Speaker Negative Wire (-): Green
Hope helps (remember rated this) TY for use Fixya.
Jun 03, 2010 | 1994 Volvo 940
I have a 1985 ford ltd. I need a wiring diagram for the radio.
modified-life-logo.gif.com can help you on this, with free diagrams on car audio install
May 03, 2010 | Car Audio & Video
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
Car audio wiring diagram for 1998 volvo s-70
CLICK HERE for your vehicles full service manual. If you are cutting wires.
Be warned your vehicle has a factory amplifier installed, and needs to be bypassed to hear the speakers if you are just wiring behind the dash.
Metra makes a harness you install on the aftermarket radio, then simply plug into the vehicle's harness.
All the wires are labeled for easy installation.
70-9220 is the metra part number. Click on the number to see an eBay auction.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 09, 2009 | 1998 Volvo S70
My 1985 Volvo GL station wagon won't pass smog the smog inspector said its probably the catalytic converter. How much on average does that cost to replace?
Since you did not post the engine size of your GL
My answer is base on a
GL L4 2.3 Liter L4 2.3 Liter engine.
The catalytic converter will cost you $181 if your car has California Emission system.
$248 for Fed. emission system.
Gaskets will cost you under $25
Look at the sticker under the hood or the inner fender for more information.
Labor is under 2 hours.
Shop around will save you money.
Mar 30, 2009 | 1985 Volvo GL
I want the wiring diagram for a 1985 volvo 244 dl
Please here to get the wiring diagram...
Good luck...
Feb 24, 2009 | 1990 Volvo 740
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
