Question about Ryobi Garden
I have a ryobi trimmer. It's about 6 yrs old. It has run perfectly until now. What it is doing is run when I choke it then it will not run after that. I have replaced the plug, put new gas in it, made sure all the fuel lines are not cloged. The pluger seems to fine. I cleaned the air filter and cleaned the screen in the muffler. I can't think of enything else....please help.
  • 1,041 Answers
First, check the fuel lines for breaks/cracks. If they are o.k. then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work due to the age of the carb. parts, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
  • Jim Parker
    Jim Parker Jun 18, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jun 23, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to start a kawasaki th48 2 stroke engine
Typically:
1. Press primer button 6-7 times until you see fuel flowing
2. Engage the choke lever to full choke /--/ pull cord 3-5 times until engine begins to start
3. Move choke lever to 1/2 choke and pull cord 2-3 times until engine starts - - allow to warm up (about 30 seconds) and move choke lever to no choke / / /
4. If engine does not start, repeat 1-3
If engine does not start, repost with more detail. Thanks! :)
Sep 25, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel lines!
Sounds like you need to adjust the carb. Remove the caps from the carb. Turn both screws clockwise until all the way seated. Start the trimmer and while running begin to back out the screws slowly until the trimmer is running strong but is smooth. Once you have the carb adjusted you can put the caps back on or you can discard.
Oct 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Lost manuel Can't start my Ryobi C530 gas trimmer
trun the on/off switch on,prime it with the bulb 3-6 times choke it , pull the cord 1 or2 times then take the choke off and pull a few times till it starts if it doesnt start you have problems.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
89 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
