Question about Superstar 3900
Superstar 3900 meter not working
The radio works fine, but the meter never moves on transmit, or receive. Any help would be greatly appreciated, Dan
  • 1,162 Answers
Need more info, is the wires soldered on, has one broken, on board do you get a reading an not on meter? Could be meter or poor solder or broken wires. Because you dont get readings at all, tells me its more likely the meter or connections
Posted on Mar 26, 2014
4 Suggested Answers
thetez
  • 32 Answers
SOURCE: My superstar 3900 transmits on one channel and receives on one ch
Ok! well i deffinitally know what the problem is. You need to play with the clarifier, i think all the way to the left is a "course and fine tune" knob. This is generally for use when talking on SSB. but may affect AM if its way off.
The clarifier lets you slide on the freq. some radios will go a full channel some will only go a little or above the center of the channel. You need to play with the clarifier, you probably need to turn the course a lot, untill the audio is almost clear on the channel you want to talk on, than use the fine to tune it in so it sounds like they are sitting right next to you.
what you should do is buy a Frequency counter, you got a nice radio, so the freq. counter wouldent hurt. lets say you want to be on channel 19. you would turn the clarifiers untill i read 27.1850 That would put you right on the money
Posted on Jan 13, 2009
  • 219 Answers
SOURCE: what chanel are what
D is your basic 40 channel, this is what most truckers talk on, then C is low, b is double low and a triple low then e is high and f is double high, this radio also has upper and lower side band, most ham operators use these channels. Hope its been convered to talk on CB band.
Posted on Nov 22, 2009
  • 219 Answers
SOURCE: a need help on my superstar 3900 the signal meter
The FM has no forward modulation. You're radio will key up but you can't transmit on it. All cb radio are like that after conversion.
Posted on Jun 02, 2010
Manaul for superstar 3900
Are you looking for the superstar model 3900 or the R.CI. superstar 3900 ?
Jun 24, 2014 | Radio Communications
Tring to wire up sadelta hand mic the mb-4 to the superstar 3900 but dont know the wiring there are 5 wires the couler of the wires are screen white red green andbrown can you help
I would like to state there are two ways to do this, one way is too open the radio cover up and look at the back of the jack where the mic goes and the color of the wires should be the same, or you can do it the second way which is a little longer and patience to do take the wires of the mic and touch one at a time to a prong one should get you sound when its right the other should transmit when you push the handle to talk on the mic
Jun 02, 2014 | Superstar 3900
Repeats selection and won't chage seletion. superstar 3600
Obviously your channel display must be working. I would assume the radio has sustain some harsh trauma to the channel selector itself possibly a drop.
Remove the speaker side cover looking down on the channel selector and its pcb board check connection and between the mechanical switch and pcb.
This may be as simple as a cold solder joint the problem is finding it.
http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif the schematic is for the 3900 which i believe are similar units.
Oct 24, 2011 | Radio Communications
I have a 3900 that has good signal but no audio check the mic and the plug out and all the joints all look good. Also checked the mic on another rig and it works fine.
Sounds like to me you regulator is bad, the dig three legged one in the back mounted to the side of the radio, if you have a meter check to see,outside legs should read 13 middle one at least 5 volts.This will cause you not to have key.
Jun 18, 2011 | Superstar SS-3900EGHPA CB Radio
A need help on my superstar 3900 the signal meter does not work on fm (rx) it key's up and stuff and is fine every where els plz email me with help charles_stewart2k9@hotmail.com
Jun 01, 2010 | Superstar SS-3900EGHPA CB Radio
Whats the wiring diagram to connect a sadelta es990 to a superstar 3900
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
Mar 30, 2010 | Superstar SS-3900EGHPA CB Radio
I have an older style Superstar 3900 that is ''deaf''
in the middle of board. towards the back there is a IC .. that is a preamp, and all the diodes for the RX and the bigger tunning transformers with the big red(sometimes) ferrites are for the RX if cannot figure it out contact me further infomatiion
Nov 03, 2009 | Radio Communications
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Jan 13, 2009 | Superstar SS-3900EGHPA CB Radio
Superstar 3900
If you have a PA function on the radio does the mic put out audio, if it does this would rule out the mic
Aug 23, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Superstar 3900 Logo
97 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
