Question about iPhone Apps
ADT Matrix not working
Fails to connect to server on I Phone
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Phone not working showing searching all the time battery ok
Please update the phone software or either restore it to factory settings.
Kindly revert back for any further clarification
Apr 12, 2012 | Uniden Cell Phones
Vonage and ADT
Does the ADT system use a phone line to call into a local police department or security team? What do you mean by parallel phone system?
Dec 04, 2011 | Home Security
We just moved into a house and it has an alarm system that has westinghouse on it. There are sensors on every door and window down stairs. We have no idea how to turn it on and get it set up.
Call an alarm company like ADT. If they can use it they will. it will require some minor reprogramming and they will check all sensors, if the use it. 1-800-ADT-ASAP.
Feb 01, 2010 | GE Security Simon 3 Wireless Home Security...
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
Alarm messes phone system
It sounds like your alarm is picking up the phone. How many rings before it picks up?
Mar 18, 2009 | BellSouth BELL SOUTH CI-36 Caller ID with...
Spooled documents get deleted
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Epson LX-300+ II Matrix Printer
To connect TVS MSP 345 Dot matrix printer with Laptop (Compaq) Usb port
Click here to open TVS-E support page, if the driver is not present on their website contact them at their toll free number.
alternatively you can download drivers below, after completing free subscription , following indication and chosing the free download to hard disk option.
download drivers here after completing a free subscription.
Nov 04, 2008 | Parallel USB Print Server 2 Port USB&1...
Disconnect and static
Hi mgee 7890,
The main thing you stated that makes me feel the issue is with a line. Maybe not ADT. Security systems sit idle until needed. However, if it is an older system and has a failure, it could seize the line and disconnect. But with the static issue, it does sound like an inside wiring issue. There may be a short in the connection to the alarm system. I would call an independent wiring person. They are cheaper and can test from end to end. When two companies like this are involved sometimes finger pointing slows getting a resolution. So this takes care of that. Also, if there is a short they will usually reconnect it so you know you have a good connection. If this helped, please rate my response. And feel free to respond if you have any additional questions.
Kay
Jackson Communications
Aug 01, 2008 | Uniden Cordless Phone
iPhone Apps Logo
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
