Question about Olympia Office Equipment & Supplies
The carriage return will not stop and keeps going back pinging the bell. The space bar appears to stop the carriage return but as soon as it is released the carriage returns.. the margins are not set
Carriage keeps returning. the space bar appears to stop the carriage return. Unable to use as no margins can be set the whole carriage just keeps returning to the left ringing the bell and slamming to a stop at the end
    New Friend:
  • 18 Answers
If this is an electric typewriter it is the carriage return clutch on the right side of the machine the needs to be serviced & adjusted.
Posted on Jun 24, 2014
  • 3594 Answers
SOURCE: return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Posted on Dec 28, 2007
JUSTOLDJIM
  • 478 Answers
SOURCE: Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Posted on Jan 23, 2008
  • 3594 Answers
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
Geno111
  • 183 Answers
SOURCE: Carriage return not fully functional.
try a light oil on the steel rod the carrier travels on, check for forien objects in the machine, otherwise take to a repair shop
Posted on Feb 27, 2009
  • 3594 Answers
SOURCE: I have the left margin set at 0 & as soon as
Put a little WD40 on the silver shaft that the carrier slides on.
DickyO
Posted on Sep 09, 2010
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
I have a Smith Cornona Electra XT. It still turns on, but when I do turn it on, the carriage automatically goes back and forth non-stop and it's like you arre holding the return button down conti
Find the problem, some linkage is sticking and you have to trace it through. Spray with WD40, then when working spray with other light oil, cause WD40 does not stay. Most likely the carriage return release . Take bottom off and watch what it hits on the left side, Also the tab button locked down will do this.
Jun 16, 2017 | Smith Corona Electra Xt Portable...
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
Have an old Brother Deluxe 650TR portable that hasn't been used for a long time. The carriage will move but will not stay at the right margin after being returned. Any suggestions?
Does the carriage just move back and forth on its own? Space bar work? The escapement may be sticky from lack of use. You may be able to see it from the upper rear or the bottom. It will move when you hit space bar or keys. Try working WD40 into it, it'll take a bit of use to free.
Nov 27, 2010 | Brother Office Equipment & Supplies
Carriage Return Inconsistency
It has been a while since I have seen a #5 Underwood. I think I still have one hidden in the attic that the wife thinks was thrown out long ago :).
The carriage return is done by the lever that pushes a pawl. The pawl engages in the ratchet teeth on the LH end of the platen. If the typewriter has the half-space feature, then it has to roll the platen two clicks (teeth) for a line space. The problems were usually in two places when this didn't happen correctly. The first is that the bushings on the platen were dry and needed oiling. The second was the follow-up roller is not clicking into the ratchet tooth and keeping it latched in the proper position. Because the platen doesn't roll far enough, or is free enough, the roller stops on top of a tooth instead of clicking into the space between the teeth. This can be caused by dry platen bushings, sticky follow up roller mechanism, or weak follow up roller spring. If you roll the typewriter on its back with the carriage all the way to the left, you should be able to pull the carriage return and watch the follow up roller action from underneath (you may need a flashlight). A light weight oil (Marvel Mystery or a sewing machine oil or Triflow) will be suffiecient to fix it usually. Put a few drops in the bushing where the steel platen shaft goes thru the end of the carrier and a few drops around where the mechanism that attaches the follow up roller to the end of the carriage. Roll the platen back and forth to work it in then slide the carriage to the right and do the shaft on the other end and work it again. Hopefully that will take care of it. If it doesn't, then the spring will have to be tightened by removing a loop. Depending on your mechanical ability and tools, that can be an easy or difficult job.
I didn't mean to write a book on the subject. I worked on mechanical typewriters years ago and hated to see them go to the wayside. I usually don't do this, but if I can be of anymore help, email me :cautionflag1956 at yahoo
Hope this helps
Jun 05, 2010 | Brother SX-4000 Typewriter
The carriage keeps going back full force
Check that the carriage release levers have freedom are are not binding. Also the tab key and linkage, next the space bar mechanism. From under machine observe the escapement wheel, rocker and the escapement pawls (fixed dog and loose dog). Lubricate with 10 weight . oil only no WD 40). The loose dog is the part that holds the carriage in position by holding the tooth on the escapement whee wheel assembly. GOOD LUCK
Nov 14, 2009 | Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
DickyO
Dec 08, 2008 | Office Equipment & Supplies
137 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
