Question about Toshiba Satellite A45-S250 Notebook
Thotkeys failure on start-up.
The hotkeys failure on start-up. I have tried several items and also in safe mode to reset thotkeys and have searched for them but they just vanished from my laptop and I can't turn on the computer unless it is plug into AC power or the screen will go very dim with no way to brighten it up.
  • 181 Answers
Are you referring to the HotKeys program? If so, download the newest version from Toshiba's site and you should be good to go.
For your dim screen, check the settings in the Power Utility for Battery power and make sure the brightness is cranked up. Other than that, a new battery would fix the issue.
Posted on Dec 07, 2007
When I turn on my computer it takes me to a gray screen declaring a failure to update windows successfully and just restarts repeats and routinly has become stuck in firsts level of computer hell.
Hi Leonard Fazio,
Have you tried going into Safe mode and the settings, control , uninstall programs - select show updates and then remove last update.
another way is to select system restore while in safe mode and restore to an earlier version depends on what o/s you have. Search for it in control panel or settings. While in Safe mode.
Jul 25, 2015 | Computers & Internet
Reset firefox
Resetting preferences
* Edit this page
* Translate this page
Show content customized for:
* Windows
* Linux
* Mac OS
* All
If you want to reset your Firefox preferences, this article provides instructions on how to reset them through Safe Mode.
To reset preferences:
1. Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Exit menu item.Close down Firefox completely: On the menu bar, click the Firefox menu, and select the Quit Firefox menu item.Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Quit menu item.
2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode).Hold down the Option key, as you start Firefox.Go to your Terminal and run:
firefox -safe-mode
You may need to specify the Firefox installation path (e.g. /usr/lib/firefox-3.5).
3. Firefox should start up with a Firefox Safe Mode dialog.
Note: You can also start Firefox in Safe Mode by clicking Start, selecting Run (or use the Start Search box in Windows 7 and Vista) and then entering the following in the text field:
firefox -safe-mode
4. To reset your user preferences, click to put a check mark by Reset all user preferences to Firefox defaults.
5. To apply your changes, click Make Changes and Restart.
Firefox will restart with your settings changed back to the defaults.
on Nov 19, 2013 | Mozilla Firefox
How to start computer when its in safe mode?
Once the tablet boots into Safe Mode, does it give any option to boot in normal mode after a restart? Can you enter Administrative Tools and view error logs? Make note of items marked with a Red symbol as they will indicate system failures. This will allow further troubleshooting.
Dec 11, 2013 | Computers & Internet
0x8007045d error the request could not be preformed because of an I/O device error
I'd suggest you to connect your external hard drive to a different USB port and try copying and check if that fixes the issue.
Also, boot into safe mode and try copying the same and check if you can successfully complete the copy operation without any errors.
Refer the below link for more details on how to start computer in safe mode:
Start your computer in safe mode
If you're able to successfully copy the file in safe mode, it indicates that one of the third party application or start up item is causing the error.
You could put your system in clean boot state and check if any third party application or any services is causing the issue and hence the error.
Putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may go ahead and disable or uninstall the same.
Follow the below steps to put your computer in clean boot state:
1. Log on to the computer by using an account that has administrator rights.
2. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
4. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
5. Click OK, and then click Restart.
Once the system is in clean boot state, try to copy the files and check if you're able to copy files without any errors.
Refer the link below for more details:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
After you have finished troubleshooting, follow these steps to reset the computer to start as usual:
1. Click Start, type msconfig.exe in the Start Search box, and then press ENTER. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
2. On the General tab, click the Normal Startup option, and then click OK.
3. When you are prompted to restart the computer, click Restart.
Jun 25, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
MD-40954 PC Notebook: what is the hotkey for getting into safe mode of w...
Restart the lappy & keep pressing F8. this will get you to the page with the options for safemode
May 17, 2010 | Medion MD-40954 Notebook
Will not open,then can't turn off
Try starting the PC in "safe mode (with network support) " by tapping the F8 key whilst it boots up and selecting safe mode from the menu. (Which bypasses your start-up items) If this boots up ok then the problem is a program that is starting up with windows, Check the start menu / programs / startup for any programs and remove them.
You can then downlaod a free program called "Spybot search and destroy" - run it, select "mode / advanced" - Tools - Startup and remove the offending item!
Apr 28, 2009 | Computers & Internet
Safe mode
Hi there, Try tapping F8 on boot to access the boot menu select "start windows normal". if it will not let you boot in to safemode with cmd promt and run "chkdsk /f" to check for bad sectors and repair othere HD issues. Also try "Last known Configuration" as a last ditch effort before moving on to System restore. IF system restore options fail to work let me know and we can do a system restore and restore your system to an earlier time through the cmd prompt. Good luck and i hope this helps
Dec 07, 2008 | HP Pavilion dv2000t Notebook
THotkey error is displayed when the laptop comes on. How do i rectify this problem?
you should have a program on the laptop, which allows you to uninstall the hotkeys.
Alternatively, re-install your laptop or computers software.
This May resolve your issue.
Mike @ Compurepair.
Feb 22, 2008 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Satellite A45-S250 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
