Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Primer bulb collapses after 3 or 4 presses. replaced both fuel lines.HELP
Pull out your spark plug after a couple of starts and see if it is dry (probably is). In that case, you need to take apart the carb and clean it out as best you can with some carb cleaner. Re-assemble and enjoy.
Posted on Jun 17, 2009
  • 1,041 Answers
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
  • Jim Parker
    Jim Parker Jun 20, 2009
    Did this solution solve the problem?
    Jim
Mod 12h802 replaced primer bulb did not help. will crank on starter fluid and run great just will not prime
It sounds like the gas line and/or the gas return line are old where they collapse or have a crack. Some carbs have two lines coming out of the gas tank, some have one line. Fuel line is cheap and most are easy to replace. If you are pressing the primer bulb and not getting fuel the fuel line is often the problem. Some tanks also have a fuel filter in the tank that attaches to the fuel intake line going to the carb. I hope this helps.
Mar 06, 2011 | Craftsman Garden
How to change the fuel hoses
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Dec 26, 2009 | Poulan Garden
Fuel lines from gas tank where do they go need picture has primer bulb
http://www.img4free.com/images/Lou98321/fuelsystem.jpg
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Garden
Fuel line placement old ones disinagrated how to
Fuel System Illustration (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/smallfuelsystem.jpg
Construct an IPL number as follows:
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
Fuel system routing is sketchy at best, fuel system components are illustrated but are on multiple pages. HTH
Lou
Dec 23, 2009 | McCulloch Garden
Chain saw, there is a line from primer to the carb, then what? I cant tell if coming out of the carb it goes back to primer or in the fuel tank? Then should there be a line from fuel tank to the primer?
Similar to this, typical fuel system.
Lou
Dec 19, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel line goes into tank bottom line has filter how long is the top fuel line? this is coming from the primer bulb.
The line with the filter needs to be long enough to reach all parts of the tank as the saw is moved, a little to long is probably better than to short. The line returning from the primer is not critical so long as it cannot fall out (mid tank). All the primer line does is return excess fuel to the tank. Does this answer your question?
HTH
Lou
Dec 08, 2009 | Craftsman 25cc Gas Line Trimmer
Saw repair
HTH
Lou
Dec 07, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Replace gas line poulan-4000 chain saw
Typical fuel system:
9803f93.gif Fuel Line Replacement by SmallEng.com
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Lou
Nov 07, 2009 | Poulan Pro Chain Saw 46cc 20"
Eager ****** leaf blower ,no fuel in pick-up line
It works like this. Just follow each line to find the incorrect connection.
79a0d89.gif Fuel Line Replacement by SmallEng.com
Lou
Nov 02, 2009 | Garden
What fuel lines go where on a craftsman chainsaw model 358-360260 / 16 inch bar? It will not keep running. I may have the hoses crossed.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Lou
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
316 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
