Question about Jwin JK-555 Shelf System
Repair parts for jwin modeljk555 cassette recorder /on/off switch
The switch on jwin not working
Video Cassette is being automatically ejected when I insert it for viewing
You need to take the cover off and look inside to see if there is something inside that should not be. Perhaps you can look with a flashlight through the entrance hole. You could pick up the machine and shake it and see if anything is rattling around. These things have many plastic and nylon parts which can break over time and the machine will sense a problem and eject. If you cannot find a problem by the suggestions above then it will need to go for repair-unfortunately it would probably cost more than it is worth to have it repaired.
May 16, 2014 | Goldstar GBV241 DVD Player/VCR
How do i repair the cd player on the cfds 01 player
Rhe repair work depends on the dianosis. Sometimes you simply can't det parts for old CD players.
So, if you know about CD repair, start by dismounting your playes and then you'll know how to repair it.
Jan 17, 2014 | Sony Boom Box With CD Player & Cassette...
I get the camera cover to open, but the camera doesn't record. It only works in the cassette mode ie play, stop, ff...
Check the tape carefuly. on the flat side of the cassette that faces upwards when you insert the cassette in the camera there is a 'record protect' switch which is coloured red. if it has completely covered the hole then it is in the 'save position' .in that case you wont be able to record.to record , flip the switch outwards with your finger nail. it should now expose the small hole. you are now set to record. please make sure that you set the mode select switch on the camera to 'camera' position.
Sep 25, 2009 | Sony Handycam CCD-TRV37 Camcorder
Suddenly my Sharp VL-Z100 can't record or play any of my cassettes! And after I finish to try to record something a red icon with an X inside appears on the screen. Anyona can help me please?
Clean up your head with the mini Dv head cleaner cassette. If still problem persists, give it to company personnal for repairing this problem, because this is the problem for the head. The head is the costly part in camcorder. So please give it to authorized person other than the local technician.
Apr 24, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Continuous beep
Hello. The TRC8080 will coontinously beep when trying to record if the tab switch (this is described in the service manual a Tab Switch S3, S4) fails. The tab switch consists of two leaf switches one is so the machine know there is a tape in the machine and the other check for record protect. Over a period of time thee canbecomebent anwill not always connect when a tape is in. This wll result in you either not being able to play a casette or not being able to record depending on which one fails. These can only be replaced as a pair. If it is not the tab switch which has failed then the cassette tabs on the top may be bent in slightly which means you will need to replace the cassette.
If the tab switch has failed and you dont want to pay for a repair you take the 5 screws out of the back of the machine, lift the top cabinet off (disconnect the single molex connector) and short the switches together. (Solder is best) this will leave the switches perminatly in the 'on' position meaning you can dictate away.
Remember if you shoose to short the switches together the motor will run as soon as the cassette lid is closed and the machine is on. This may make the motor fail a little bit earlier than normal.
Apr 24, 2009 | Sanyo TRC-8080 Desktop Cassette Voice...
Record problem
There are two things 1.there is a push switch under the cassette holder may be brocken 2.cassette holder is bad.put a cassette and press on cassette holder then try this way you can make sure which part is bad.
Jan 30, 2008 | JVC COMPACT VHS-C CAMCORDER
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Jwin JK-555 Shelf System Logo
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
