Question about Covercraft Block-It 200 Custom-Fit Car Cover for a Toyota Corolla
Fuse for Dash Board Light and Gauges
Need to replace fuse, but don't know which fuse is for the DashBoard and Gas Gauge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Check your Owner's Manual. If your look in the back of the manual, you'll find a diagram which shows each fuse and its location on the fuse block.
Posted on Mar 24, 2014
My dials on the dashboard don't light up
Check all the fuses for the instrument panel lighting.
Check all the light bulbs behind the instrument panel.
Replace all burnt fuses and light bulbs.
Oct 09, 2014 | 1996 Mitsubishi Montero
Fuel indicator
The sensor in the gas tank is faulty, the fuse has blown or the gauge at the dashboard side if faulty - try disconnecting the wire attached to the gas tank end and ground it - if the gauge should indicate a full tank - if so then the float unit in the tank need replaced - if it doesn't move then it is either the fuse or the guage.
Feb 07, 2014 | 2005 Bajaj Pulsar 180
The gauges on dashboard are not working
Sound like a fuse blow problem; I suggest check and test each fuse acco4rding with the fuse description in the Owners Manual.
Other choice could be some loss harnesses connections, will need take off the dashboard to check it.
Hope this helps.
Feb 09, 2012 | 2000 Buick LeSabre
Which fuse runs the lights on the dashboard? fuel gauge and speedometer don't light up!
This is the PARK LAMP fuse . So check this out on the under side of the dash and use a nose plier to pull the fuse out to be replaced by the spare in the box.
If the fuse seems ok, then check the harness, connectors to the dashboard cluster or the lamps within the dash.
Jul 22, 2011 | 2000 Toyota ECHO
I have 1991 BMW 535 i and my dashboard keep showing this message "brake lining" I don't know what's going on. Also my gas indicator is not giving me the right reading
The "brake lining" means your brake pads( on one axle) have worn to its service minimums and will need to be replaced soon. Have your brakes serviced. continued operation can cause brake rotors to become damaged from metal to metal contact.
The incorrect fuel gauge reading could be caused by several causes, but most likely a worn out fuel level sending unit.
Jul 19, 2011 | 1991 BMW 5 Series
The gas gauge don't work
Hello and welcome to FixYa!
As a first course of action, please do check the fuse. If the fuse is blown, the fuel gauge won't work. If that's the case, please replace it.
If the fuse if good then the problem will be on the fuel float itself. The fuel float is located above the fuel tank. You will need to pull down the fuel tank to gain access to the fuel float. Once replaced, the fuel gauge will work normally again.
Hope this helps and thank you for using FixYa! Have a good one!
May 11, 2011 | 1996 Chrysler Town & Country
After i start my chevy malibu maxx all the dashboard lights go on, the radio shuts off and the gas gauge goes down to e.it is as if the car has lost power the car does not stall after a few seconds all the...
We had a similar situation. It took the dealer a few days to figure out it was an issue with the wiring harness(es) in the center console - around or behind the transmission shifter.
Sep 25, 2009 | 2004 Chevrolet Malibu Maxx
Gas gauges and temp gauge stopped working on my 99 jimmy any idea
check fuse box,under your dashboard or hood.look for small print,that indicates the fuse operations
Apr 14, 2009 | 1999 GMC Jimmy
Chevrolet Blazer 1997.
If sender is new in the fuel tank, you have a wire problem between conection of fuel sender and dashboard gauge most likely place at dasbboard gauge.
Nov 27, 2008 | 1997 Chevrolet Blazer
Covercraft Block-It 200 Custom-Fit Car Cover for a Toyota Corolla Logo
73 people viewed this question
Top Driving Comfort Vehicle Parts & Accessories Experts
Robert Plante
 John
John
 AEpittsburgh
AEpittsburgh
Are you a Driving Comfort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
