Question about Pool & Spa
My Laguna Spa is showing a code on the screen. It is CPo. Any thoughts? Thanks.
Have not used my spa in some time but it was always running. I emptied it and refilled it yesterday. I set the temperature at 95. When I went out today to chlorinate it, the temp was already up to 90 and the heater pump was running. I put the chlorine in and hit the button to start the jets. A message came up that said CPo. The heater pump then wouldn't run but the jets worked fine. I turned it off at the breaker. Thanks for your help.
  • 717 Answers
Here is a link to the most common error codes and what they mean.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
us parts center
Posted on Apr 08, 2014
  • 272 Answers
SOURCE: no chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Posted on Jun 01, 2009
SOURCE: Intex system not giving chlorine, no errors but no green light
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Posted on Aug 02, 2009
  • 1498 Answers
SOURCE: pump was working fine yesterday popped the breaker
Hi Mohn,
Don't know your geographic location, but where I am we've been in the single digit temperatures for three days. Everything that can freeze has frozen.
If you are in a similar area, even though the water in the spa (I'm assuming the spa pump is being used on a spa) is heated, the pump housing isn't. If it iced up, it could very well cause the problems you describe.
Comment back with some more detail before I continue down what might be the wrong path.
Best regards
Posted on Dec 11, 2009
  • 1378 Answers
SOURCE: I run the filter pump then turn on the salt water
pH will always rise over time when using a salt generator. You'll need to periodically add acid to counteract this affect. As far as low chlorine levels try running the system longer...An average pools circulation system is setup to turn over the pool water once in about 8 hours. Running your system longer should lead to a higher chlorine residual and overall cleaner water.
Posted on Apr 26, 2011
  • 4803 Answers
SOURCE: spa kicks off in a cycle. needs to be reset
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Posted on Dec 17, 2011
I need help to fix my spa, Error code CPo
circulation pump overlimit pump is overheating replace
Jun 25, 2017 | Pool & Spa
OH code for x500 how to repair?
if water flowing possible bad temp sensor or recirculation pump running too slow
Jun 13, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Compool cp3400
online/Amazon - but the best thing is to use your local pool spa professional. Then you can always call them for help when you really need a pro.
May 22, 2014 | Pentair Pool & Spa
6521 REV GGG code
check 4 pin red plug inside to see if shorted wire ends or cut wire to controller
Apr 29, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Max Pro 1500 motor starts but then stops within 10 seconds. Does not run continuously. Cleaned inside and put back together but problem still continued.
Your problem is the thermal switch is tripping off. this means there is some supply or voltage problem. Most likely fix is replacing the capacitor.
Jul 19, 2011 | Hagen Laguna MaxFlo 1500 Electronic...
Hello, please tell me what breaker (amps) do I need to use with Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11. What is the normal amp consumption for this equipment? Thanks
Hi and welcoe to FixYa, I am Kelly.
11,000W is the maximum power that it could draw. Given the wattage is over 10,000 I am certain that your Spa / Tub heater is 220 VAC If it is 220 VAC then you will need a 50 Amp breaker. If it only 110 VAC you will need a 100 Amp Breaker. (Gasp!)
Amp consumption will always vary.
Heater on / Off
Number of Blowers and pumps in operation at any given time. Then add lights to the equation. My best guess at any given time it is in "full operation" it will average 6,000 - 7,500 watts. When not in full use it the average amp usage would drop substantially.
Thanks for choosing FixYa,
Feb 21, 2011 | Hayward 11kw Electric Spa Hot Tub Heater...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
1,085 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
