Septic vs washout tub?
I do not want to use my washout tub anymore. I want to connect straight to septic about 7' above floor. A) Do I need a straight pipe. B) How long of a straight a straight pipe? C) Will any water come back into the washer?
  • 33 Answers
Waste water from the washer is not pumped out but rather is gravity fed down the drain. You cannot drain the water up higher than the washing machine's drain outlet. You would have to cut into the drain pipe - below the level of your washer's drain outlet - and put in a T that will tie into the drain pipe and allow for some type of connection to be made from your washer's drain hose.
Posted on Mar 23, 2014
Testimonial: "My washing machine is in the basement so tying the line to a T connector is not an option. If the waster is not "pumped" out of the washing machine then why is their a 8' height limit in the manual?"
  • cajuncharger Mar 23, 2014
    Hmm, ok, maybe yours does have a pump. If it gives you a height limit then you should be okay as long as you stay beneath that. What is the drain pipe you want to tie into made of?
  • Michael Decker Mar 23, 2014
    PVC so I'll be tying into it w/PVC as well. The PVC pipe is tyied into the cast iron ser line further down.
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
  • 22 Answers
SOURCE: water on floor under washer
Could be splash.
If you tip washer back and look under bottom, do you see water dripping in area of black motor--even small drip? if yes, look at my post on "eco smart won't drain, smells hot".
Mine started with a little water leaking. After a few loads of small leaks, it wouldn't spin out at all--would shut itself down and then I smelled hot electric motor. You need to remove white plastic housing/black motor and replace this unit. see my issue on how to remove--it's easy to do.
Posted on Oct 20, 2008
  • 77 Answers
SOURCE: Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Posted on Apr 26, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
Posted on May 02, 2009
mkh5094
  • 145 Answers
SOURCE: Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Posted on Apr 27, 2010
Crook well council says all water from shower and kitchen is septic and could contain facial matter and have to be connected to septic tank thanks george
So, you need to call a septic company and plumbing service to connect both kitchen and shower drains to septic tank.
Jun 17, 2015 | Plumbing
Septic Tank Drain Field
In numerous septic system, waste from toilets, bowls, showers, showers, floor drains and bowls courses through a labyrinth of funneling out to your septic tank or cesspit. The septic tank is typically framed of concrete or gum in more up to date plans with either apertures inside of the tank itself or downstream in the channel or field lines on the surge side of the septic system. Restrictions prevent the waste layer from leaving the tank and compacting the drain ranges. TG Wastewater
Mar 19, 2015 | Plumbing
Smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Apr 03, 2014 | Maax Breeze: One Piece Round Shower...
Would a vent problem cause the water to back up in the tub and cause the toliet to bubble?
A vent would cause an odor problem but not a back up problem. There should be a clean out between the house and septic tank, if it is full the blockage is down the line, if its dry the blockage is in the house.
Nov 20, 2012 | Dishwashers
Water level sometime very low, sometimes very high (almost overflow) and eventually returns to normal level. time can vary from 30 minute to 12 hours. at end of flush often a big explosive air bubble....
I would say the first thing you should do is, drain out your toilet using a cup and sponge, remove the toilet from the floor and inspect the base of the toilet for blockage. Also check the floor floor and gasket to be sure there are no restrictions. If all is clear then run a garden hose full pressure into the drain and see if it backs up. If the drain is blocked and you don't have access to a drain snake then you an go to a local hardware store and buy what is called a drain king that connects to the garden hose and pressurizes the drain to clear the blockage. If you dig up the septic lid make sure you have it pumped at the same time.And as always don't forget to use your rid-ex every other month. Hope this helps.
Feb 18, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
My toto toilet on average needs 2-3 flushes. It seems as though air is coming up into the bowl. I checked the vent and it seems ok. I already replaced the flapper but that was another problem. Any advice?
If your on a septic system the air coming back is telling you one of 2 things. Either the septic tank vent is clogged or the Septic tank itself is full.
For a non septic system you can have a restriced toilet drain or clogged pluming vent outside of the home. Most of the time the vent goes straight up to the roof within a few feet of the actual intalled water closet / toilet. Check the vent to see if the birds have built a nest in it or that someone got a bit over zealous with winterizing the home and placed a bag over the vent. If the vent is clear your going to have to find out where the restriction is either in the toilet bowl passages or you home plumbing. Sadly this usually involves removing the toilet from it's mount and stinking up the home. If you remove the toilet bowl in your troubleshooting process your going to need to replace the bees wax floor seal when you re-mount it to the drain. A word of advice on checking the vent... Use a vacuum that is blowing air and a rag to assist in covering the hose to see if you get air bubbles in your toilet bowl. Do NOT use your mouth to do this. It could ruin your day.
Jan 21, 2010 | Carolina Manufacturing TOTO MS884114#01...
What is the typical vertical height that a washing can pump water
5 feet should work to pump out BUT the water left in the hose will drain back into the machine. It may, or may not hurt anything, but it may be enough to leave water reaching the inner tub. If that happens, the clothes will still be wet. You may end up having to put the washer onto a platform a foot or so off the floor. Try it first, it may be fine.
Dec 29, 2009 | Kenmore Washing Machines
Washing machine is in the basement. we have a new septic system and the washer had to be hooked into the septic. (it previously had gone into a dry well. To do this we have the hose of the washer going up...
yep actualy a fairly common problem install a laundry tub with a pump and a diaphram switch (similar to a float switch but neater) will save your washing machine pump too Good Luck
Oct 12, 2009 | Washing Machines
Error 4 in bosch nexxt washer
After browing a little more on this forum, I found the solution to my problem.
There was an hairpin stock in the rotating device that is located behind the front plastic cover.
Thank this website was very useful to me. Hope it can help someone else too!
Jan 13, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
