Question about Radio Communications
I broke the plug for the oxygen sensor 1 bank 1 on a toyota camry v6 and need to know which wire connects to which pin..
I was replacing the rear (bank one, sensor one) oxygen sensor on my 1995 toyota camry and the plug broke in my hand. I need to know the correct wiring sequence going to the O2 sensor for proper connection.
    Scholar:
  • 116 Answers
This is not a CB radio related question so I cannot answer.
Posted on Jul 09, 2014
Mechanic688
  • 204 Answers
SOURCE: wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Posted on Jan 13, 2008
Mechanic688
  • 204 Answers
SOURCE: Omegaforce s45 mic wiring
Sadelta
1-Shield - Ground
2-White - Audio
3-Brown - Transmit
4-Green - Receive
Does this color code look like what you have in your mic?? sorry for the delay,,, Mechanic
Posted on Nov 05, 2008
  • 6 Answers
SOURCE: wiring is broke on 4 pin mike plug
This is the wiring for a stock mic ... if it is a different one let me know
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Posted on Apr 07, 2009
One Wire
  • 126 Answers
SOURCE: turner Rk 56 mic
Here is the wiring information for a Turner RK56. If the picture is too samll for you too see or it does not load up, email me at rollincbmods@yahoo.com with the subject as RK56 wiring diagram needed, and I will email it to you.
Dean Pitts
Rollin CBs
Posted on Jun 02, 2009
SOURCE: wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
Posted on Nov 30, 2009
Need to locate oxygen sensor 1998 camry v6
follow your exhaust system you should see them in the pipe you have 1 up near manifold or in the manifold and the other after the catalic converter 4 cycl have 2 6 cycl have 4 also you have up stream bank 1 sensor 1 bank 2 sensor 2 bank 1 sensor 2 bank 2 sensor 1 and downstream as well so some models before cat converter and after
Jul 04, 2014 | 1999 Toyota Camry
2002 Toyota Camry oxygen sensor Bank 1 Sensor 2 location
go to manifold follow it till you find the downstream sensor there you go
Jul 21, 2012 | Cars & Trucks
What code mean po302,,,,po135...p1705
P0302 TOYOTA - Cylinder 2 Misfire Detectedxicon.jpghttp://engine-codes.com/p0302_toyota.htmlForum CodePossible causes- Faulty spark plug 2
- Faulty ignition coil 2
- Ignition coil 2 harness is open or shorted
- Ignition coil 2 poor electrical connection
- Clogged or faulty fuel injector 2
- Injector 2 harness is open or shorted
- Injector 2 poor electrical connection
- Improper spark plug 2
- Insufficient cylinder 2 compression
- Incorrect fuel pressure
- Intake air leak
P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1xicon.jpghttp://engine-codes.com/p0135.htmlForum CodePossible causes- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Faulty Engine Control Module (ECM)
Tech notes The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The Engine Control Module (ECM) monitors how long it take the sensor to warm up and start sending an adequate signal. The code means the the sensor is taking too long to warm up. Replacing the O2 Sensor 1 usually takes care of the problem
P1705 TOYOTA - Direct Clutch Speed Sensor Circuit Fault.
This is related to the sensor that gives info about the slippage rate o fthe transmisssion to the Transmission Control Module..
Jul 15, 2012 | 1996 Toyota Camry
Code 28, 93 toyota camry le v6, what is the fault
This is a fault with the Oxygen sensor on bank 2
Mar 09, 2011 | 1993 Toyota Camry V6
How many oxygen sensors does my 1994 toyota camry V6 have? How do I find out which sensor is bad? I have check engine light on.
v-6 has two O2 sensors, one located in the exhaust manifold and the other near the catalytic converter
Mar 06, 2011 | 1994 Toyota Camry
Where is oxygen sensor 1 on a 2000 camry v6
did it say upstream down stream bank one or bank 2 because the upstream( bank one) is the first ine in the exaust and down stream(bank two) is next in line
Nov 21, 2010 | 2000 Toyota Camry
Where is the oxygen sensor, bank 1 sensor 1, located on a 2000 Toyota Solara? What is the best one to purchase for replacement?
B1S1 means first (upstream) , closest sensor to cyl. head , usualy at exhaust manifold.Bank 1 is cyl. head with cyl.#1 if you have V6 engine.
Best choice for brand - Denso.
Apr 27, 2010 | 2000 Toyota Camry Solara
Find get at the wire and plug for the oxygen sensor on 2001 toyota camry 4-cyl
Unbolt the pass side seat (only 4 14mm head bolts) and lay it back. This will give you the room you need to pull the carpet back from the console area and get to the plug.
Apr 12, 2009 | 2001 Toyota Camry
Catalytic converters
If you are going to change the convertors I would just replace the first one closest to the engine. But when a computer code says "bank" they usually are refuring to the Oxygen sensor that is there , they are classified as bank 1 and bank 2. 1 being closest to the engine and 2 being farther down the exhaust. If its a computer code that told you bank 1 you might need to look at your oxygen sensor instead of your catalitic converter.
Dec 04, 2008 | 1996 Toyota Camry
Radio Communications Logo
51 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
