Question about Garden
I need to a picture of how put the pto drive belt back on a bg1860 kubota
    Guru:
  • 145 Answers
5 Suggested Answers
bbreton
  • 437 Answers
SOURCE: The belt came off my mower and I need to know what
Try going to kubota.co.uk and see if a diagram is available there.
Posted on Oct 07, 2009
  • 133 Answers
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from coming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Oct 24, 2009
  • 6468 Answers
SOURCE: husqvarna riding lawn mower pto is not engaging?
when you dropped the deck did you knock off the pto electrical plug?
Posted on Apr 02, 2012
  • 6468 Answers
SOURCE: i engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Posted on Apr 08, 2012
I have a kubota L 2800. The pto keeps spinning when I turn the pto switch off. However, if I keep moving with the pto switch off, eventually The pto stops spinning.
indicates a rusted , binding section on the spline connected to the pto plate not allowing it to slip free with no power applied
Feb 07, 2018 | Kubota Garden
How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
May 11, 2017 | Garden
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
PTO lever engages in the wrong position in a Kubota ZD323.
Check and make sure that any links are not bent and make sure that the switch that engages the PTO is not out of adjustment.
Jul 14, 2016 | Kubota Garden
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
Kubota T1600 slings off PTO drive belts
Not sure, but it sounds to me as though it is simply a belt guide either missing or bent out of adjustment, if the belt is easy to get back on then this is where the issue lies. I hope this is helpful.
Sep 29, 2013 | Garden
I have a Kubota TG1860 G riding mower. the blades have stopped engaging. I have replaced the push/pull switch, didn't work. It clicks like it wants to work but doesn't engage. What else can I do?
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
Apr 18, 2011 | Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
