Question about Frigidaire GLEQ642A Electric Dryer
GAS dryer will operate, but not heat. No error codes showing
The dryer is all of a sudden not heating, but otherwise seems to be working fine. Loads need to be go through several cycles to dry.
    Habit-Forming:
  • 103 Answers
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Posted on Mar 24, 2014
SOURCE: Intermittent Heat
For what its worth, I found out what was wrong with the Kenmore Elite 110-62882101. The circuit board works a small relay that works the heating element. We replaced the thermister, then the circuit board - to no avail! Finally, we replaced the relay, and the problem ended. Seems that the relay didn't always make up even though it clicked. It's a Potter Brumfield (and old line company) but made in China (what isn't?). The guy is the local parts store says the motor relay is the same type (they look alike) and that these caused trouble in the past. The heat circuit didn't use relays in the past (when there were thermostats), but they do now (that temperature is controlled by thermisters and circuit boards). So, the lowly, seemingly simple and reliable heat relay can be the problem - if your dryer has one. --- Powerguy
Posted on Mar 04, 2008
ngfam1
  • 639 Answers
SOURCE: DRYER WON'T RUN UNLESS YOU HAVE NO HEAT
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
When you get codes it's over!
These are electronics!
Time for the professionals!
For this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer is getting hot but clothes are not drying
You have a vent problem. Eliminate all (if possible) flex duct (replacing with ridged aluminum pipe and aluminum elbows). Clean lint out of remaining vent pipe. Make sure vent is not crushed or obstructed, especially behind the dryer. If possible, make sure outside vent termination is not a two inch opening. (you want a full 4 inches)
Posted on Nov 10, 2008
  • 291 Answers
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Posted on Nov 23, 2008
  • 17 Answers
SOURCE: My Frigidaire dryer model GLER642AS3 is not heating properly
If you have heat in the dryer, then its probably the venting blocked
Posted on May 16, 2010
Our dryer will heat sometimes and then not at all. As much as a week will pass with no heat and all of a sudden the heat comes on for a load. A serviceman replaced a thermostat and a high limit switch and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 24, 2011 | Dryers
Will not generate heat runs fine-it's only done about a 100 loads
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 01, 2011 | LG DLE1310 Electric Dryer
Drier has no heat. Seems to run fine, otherwise. might I nee d to re-light the pilot through the small hole in the front of it?
heatman101
Jan 24, 2011 | Kenmore 60172 Electric Commercial Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
No heat, dryer works fine otherwise
heatman101
l'l'
Aug 05, 2010 | KitchenAid KGYS750LQ Gas Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
