Question about Peg Perego Vespa Scooter
Vespa lx50 wont start
Vespa lx 50 wont start. checked spark plug, ok but changed it any way. Before it stopped working it was idling rough for 1st few minutes. Checked air filter, checked plug for spark, considering fuel additive next since gas is old
3 Suggested Answers
  • 6 Answers
SOURCE: Trouble Starting VESPA
Check for bad gas -- water in gas , it is likely you have left the choke on.
Posted on Jun 03, 2009
  • 43 Answers
SOURCE: think flooded carborateur lx 50 vespa ,what do i
how do you know the carb is flooding? Flooding is caused by a stuck float valve. Disassemble and repair.
Posted on Dec 31, 2009
2013 Vespa LX 50 cuts out
Hi, Koppi if your bike has been sitting idle for weeks, months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will not idle unless the choke is full on and run poorly then stall, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition and in the future use a fuel stabilizer before putting your bike in storage for the winter.
1. If your battery was 2-3 years old when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging the battery remove the leads and let it sit for a couple of hours then check the battery voltage with a voltmeter, you should have 12.5 volts or more, any readings in the 11 volt range you need to do a proper "LOAD" test on the battery and replace as necessary, you may have 12.5 volts or better but little or zero amps, any readings in the 10 volt range you have a dead cell and the battery needs to be replaced.
4. Drain and flush fuel tank if it rusty there is a cheap and easy fix. https://www.youtube.com/watch?v=fUYr_7SwGms
5. Remove and inspect your air cleaner paper elements that are not oil soaked can be cleaned with a soft brush and low pressure compressed air, oil-soaked elements must be replaced. Gause mesh and foam elements can be cleaned by soaking them in a container big enough to completely cover them with a solution of 1 gallon of water and 1 oz. of Dawn dishwashing liquid for small and medium size elements, for monster size double the formula and let soak for at least one hour then rinse with warm water shake off excess and let air dry, "WARNING" do not use compressed air as this will embed micro-sized dirt and road grime and destroy the mesh pattern and stretch foam elements out of shape just squeeze it like a sponge and let air dry, use a fan if you're in a hurry. When completely dry spray a very fine mist of air filter oil evenly around the whole element.
6. Remove the carburetors, disassemble and decontaminate with a "CARB DIP" or if you have EFI remove injectors and clean with carb spray and compressed air
7. Check intake manifold and seals for leaks and craks.
8. Remove fuel valve and filter disassemble and clean as necessary, remove, clean, and inspect fuel and vacuum lines and replace as necessary.
9. Replace spark plugs with new ones and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Help Vespa 50LX engine stops after 2 3 miles some 10 min
Motorcycle Views
VESPA LX 50 Workshop Manual
https://www.piaggiopartspro.com/oempartfinder.htm?aribrand=PVS&gclid=EAIaIQobChMI-s2p9tWW2wIVicVkCh0ucwzbEAAYASAAEgJwEvD_BwE#/Piaggio_Vespa parts fiche
Vespa LX 50 User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 20, 2018 | 2011 Vespa LX 50 2T
How do I fix a vespa lx 50
Hi, J I am sorry you can't find the first and best tool you ever bought for your Vespa but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2006 Vespa Lx 50
Oct 31, 2015 | 2006 Vespa LX 50
Gas overfill - Vespa LX50 won't start
It is unlikely that being unable to start is caused by overfilling the tank.
Remove the spark plug, clean it with a wire brush, and check for a spark. Turn the ignition on, put the spark plug and lead attached against the cylinder head and kick it over. You should have a fat blue spark under the electrode. Check the gap and replace the plug.
Another thing you can check for is either a pinch or an airlock in the fuel line to the carburetor.
Jul 30, 2017 | Sport & Outdoor - Others
Vespa ET2 50 Motorcycles carburetor tuning
Hi, Juan if you have changed your engine size, fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. A wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
Vespa ET2 50 cc Scooter Custom Performance Carburetor Carb Stage 1 3 Jet...
STEP 1 ADJUST IDLE MIX FASTER SCOOTER EPISODE 4
Carburator Theory and Tuning
Vespa VESPA ET2 2001 Parts
Dec 16, 2017 | Vespa ET2 50 Motorcycles
My vespa lx 125 ie is having problems starting, what could this be?
Hi, Josmerriman9 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Modern Vespa Vespa LX 125 startup problems
http://modernvespa.com/forum/wiki--won-t-start-diagnosis-for-beginners
http://www.vespaclub.org.pl/images/manualki/lx/LX-S-125-150-3v-ie.pdf
Products at Vespa Genuine Parts
VESPA LX 125 150 Euro 3 User Manual
Jun 16, 2011 | 2011 Vespa LX 125 ie
My Vespa LX50 won't start.Some days I've been trying for an hour and nothing happens, I've tried kickstart and start button and nothing. I have been to 3 workshops and they cannot identify the problem....
I have had the same problem with my LX 50. You have to make sure you turn it on often to keep it in good shape. I didn't turn it on for a long time during the winter and it didn't wanna start in the spring. I bought a fluid that you put in the gas tank that cleans off the insides when the gasoline runs through. I have to double check what fluid it was. But it worked and now it turns on.
Aug 18, 2009 | Chicco Vespa Sit N' Ride Scooter
2006 lx50 still won't start. Changed the plug and still no spark. Should I just go ahead and replace the wire and coil? Anybody?
put your finger on lead and turn her over-that should answer if magneto is cranking any power to your plug-ps wear rubber boots and hang on to your best mate!lol
Jul 04, 2009 | Peg Perego Vespa Scooter
Rough idle
check ur coil pack for cracks my wifes cousin car done the same thing and the coil pack had a hair line crack in it
Jun 15, 2008 | 2003 Ford Focus
Peg Perego Vespa Scooter Logo
379 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
