Question about Philips LX3000D System
How do I set up my Phillips lx 3000 mini PC to work through my TV and Bose system, connections.
I have visuals but no sound
Bose solo not working on phillips tv
retest the hook up for this condition and proceed.
Jul 09, 2013 | Bose Solo TV sound system - Black
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
I have a Bose 321 that I have connected to my TV and it works with no problem. I just bought a Panasonic Blu-Ray disc player and connected it to the TV using a HDMI cable. I then connected the Blu-Ray to...
hi,
u have to change the digital out setting of ur blueray player. change the audio output priority from HDMI to optical coaxial. surely u will get audio from bose.
ok
Dec 24, 2010 | Bose 3·2·1 Entertainment System...
Bose 123 system and Samsung LED TV problem.....
yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
good luck dude
Sep 08, 2009 | Bose Cinemate Digital Home Theater System...
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
I have a sony PS3 and a Bose 321 gs series 2 sound system... how do i connect them to my Phillips 52pfl7403d/f7? I can get the PS3 connected just fine but I cannot figure out how to get the audio to play...
u have to go to radioshackand get a 1/8 to dual rca y-adapter then u plug it in to ur tv , if its a philips like u say itis it has a audio out put for headphones on the left bottom corner on the back of the tv, just plug it in and then lower the volume on the bose system and on your tv remote press menu, tv menu will come on on the tv screen go to it, or press ok on the remote, on tv screen will say tv setting press ok on remote, go to sound, go to headphone volume, put it on 60 its the perfect setting on for your tv DO NOT go over 65 it will distotion the equilizer on the bose, well this work for me but if i find out an other way ill let you all know
Mar 05, 2009 | Bose 3·2·1 II System
No audio out connecter on back of Phillips 52 in TV
Hi and welcome to FixYa,
Almost all (European) Philips have a SCART type connector as shown below.
With the use of a SCART Adapter (below), the outputs are available as Audio L/R & Composite Video and S-Video either as output or input.
Good luck and thank you for using FixYa.
Feb 09, 2009 | Bose Cinemate Digital Home Theater System...
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Nov 02, 2008 | Bose Lifestyle 30 System
Am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Jun 23, 2008 | Bose Cinemate Digital Home Theater System...
Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Dec 16, 2007 | Bose Lifestyle 28 System
Philips LX3000D System Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
