Question about Ortho Dial N Spray Hose End Sprayer
Water gushing from trigger
Water is gushing from the trigger site.
I am trying to install a new water filter and water wont stop gushing
There is an oring ( black washer that looks like a black band ) that is not in place . You must have that to keep it from leaking.
Mar 01, 2013 | GE Smartwater Refrigerator Ice Maker...
Noisy Hot Water Gushing In Boiler
You may excess air in the lines
Nov 06, 2012 | Water Heaters
2001 Jeep Grand Cherokee Larado has water pouring out from under the dashboard on the passenger side. Help!
The water gushing in on passenger side, is probably antifreeze, check that the heater core isn't leaking. If it is gushing try and capture some of this water and and see if it is antifreeze or just water. If antifreeze then it's the heatercore if water the. It's from the a/c
Sep 15, 2012 | 2001 Jeep Grand Cherokee
My pressure washer gushes water from the inside of the trigger handle with some water still exiting from the end of the spray, will unscrewing the 5 screws which hold the trigger head together get me...
If you are willing to try, take out the screws. You will probably find a worn or broken O-ring or a broken diaphram. Replace them or it and you should be good to go! Good luck...
Apr 28, 2011 | Garden
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
No pressure but water is gushing out from the inside
You most likely have split the head of the pressure pump. This happens if you use the trigger to stop and start the water flow. My advice is to put a zippy tie around the trigger holding it on all the time and start and stop the machine by the knob on the body.
Apr 12, 2010 | Karcher K2.26 Electric Power Washer
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Ortho Dial N Spray Hose End Sprayer Logo
155 people viewed this question
Top Ortho Garden Experts
raysaw
Nick Olsen
Are you an Ortho Garden Expert? Answer questions, earn points and help others
