Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Starts but gets hot and stops will not restart
    Scholar:
  • 81 Answers
If you can restart the machine after it cools down with no problems, you need to replace the electronic ignition.
Posted on Jun 15, 2009
HOW CAN I STOP MY 1986 MORGAN 4 X 4 MISFIRING AND DIFFICULT TO RESTART WHEN HOT
Plugs, plug wires, distributor cap, rotor button basic tune up is where to start.
Jul 19, 2016 | Morgan Cars & Trucks
Chainsaw won't start?
2 possibles
coil is getting hot and failing
do you have spark straight after it stops
is air filter clean
carby diaphragm or carby rebuild required
May 31, 2016 | Garden
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
SS 5060 wont start when hot
Most likely the valve timing needs adjusting. When cold the metals are slightly smaller so the valve timing is just enough to start it. After about 10/15 mins when full engine temp has been reached and the valve stems, cams and seats have all expanded, fully and the valves no longer close fully so compression is lost , (it may then stop) it may keep running through momentum but you may notice a reduction in power. Once stopped it will not restart when hot as the valves will not be closed fully and not allow the fuel to be compressed to combustion.
Oct 05, 2015 | Garden
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 | Garden
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
Sep 19, 2014 | Heating & Cooling
Car star when is cold but if I stop the engine after is hot it will not start until cool of again
If you mean that it starts fine when cold, but if you stop & turn off the engine (to to pop into a shop for example) then try to restart and get absolutely no turning over, then you need to replace your battery. It has a short or crack which is expanding when hot creating your problem.
Jul 31, 2012 | 1997 Ford Explorer AWD
When I first start my jetta a flashing red symbol immediately comes on and stays on until I stop and shut my car off and then restart it. If I stop and restart too soon it will come back on so I have to...
Hi,these cars have problem with there coolant level sensors in the bottle to replace the sensor the bottle needs replacing.the sensor pins get corroded.regards
Jul 06, 2011 | 2004 Volkswagen Jetta
2001 chevy s10 loses power, will not stall, restart runs better.
SOUND LIKE ENGINE GETTING TOO HOT.THAT WILL CAUSE LOST OF POWER.CHECK COOLING CLUTCH FAN IF IT HAS RESISTANCE WHEN ENGINE HOT FAN CLUTCH IS GOOD.IF FAN CLUTCH FREE WHEELS WITH NO RESISTANCE WHEN ENGINE HOT.FAN CLUTCH IS BAD.THAT WILL CAUSE ENGINE TO RUN HOT WHILE DRIVING.
Jul 23, 2010 | 2001 Chevrolet S-10
Engine cuts off starts when it cools off 1991chevy lumina drives for a bit then stops let sit for a few minutes and restart it
Sounds like the ignition coil is getting bad it gets hot and stops working and when it cools off it works again. I would replace it and your problem should be solved.
Feb 26, 2009 | 1993 Chevrolet Lumina
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
170 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
