Question about Dryers
Huebsch dryer troubleshooting
I have a Huebsch Commercial Super Capacity Plus Electric Dryer Model #LEZ57AWF1702. It ran for 5 minutes and a sharp ping/noise was heard and it stopped running. Now after 4 hrs of cooling it still will not run/start at all. Any suggests would be greatly appreciative.
    Sergeant:
  • 446 Answers
Could be door switch
Posted on Mar 24, 2014
  • 12 Answers
SOURCE: Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Posted on Feb 28, 2008
ghappliances
  • 126 Answers
SOURCE: Old Kenmore 30BG dryer
YOUE BEST BET IS TO CONTACT SPEED QUEEN APPLIANCES AS THEY ARE THE NUMBER ONE SUPPLIER OF INDUSTRIAL WASHERS AND DRYERS.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: Huebsch Electric Dryer won't dry
Look for a faulty high limit due to excessive lint buildup in the machine. That or either the element is bad. very simple machine to repair. Huebsh electric? Better look at old style speed queen dryers for comparison. better yet Click THIS
Posted on Jul 08, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Posted on Apr 22, 2010
Err message. What causes this?
Owner's manual, troubleshooting. No manual, or lost, try
manualslib.com or MFG website, or their customer service email.
Apr 07, 2015 | Dryers
Commercial huebsch dryer keeps coming up door as problem ,runs for 20 secs. and stops
check out the door switch, may be bent out of place or worn out.
Nov 12, 2014 | Dryers
Dryer filter model 37AC size 37 X30
www.huebsch.com/support/technical-literature
May 23, 2014 | Huebsch Parts Dryers
Huebsch dryer parts
May 23, 2014 | Huebsch Parts Huebsch H96382106 Dryer...
Dryerstartsbyitself
Hi check the door switch is set properly.
Mar 07, 2014 | Huebsch Parts Huebsch 254P4P Washer HOOK,...
My dryer is not blowing hot air? I have a whirlpool, commercial quality, super capacity plus, 8 cycles & 4 temperatures. help.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Dryers
Commercial dryer not getting hot
Check draft switch on back of dryer have had wire ties break and wires get in way of flap.Make sure when closing door when dryer running draft switch is pulling in.If it is not pulling in check for back drat flap inside where your exhaust is hooked up have had those stick closed or someone ran self taping screws in front of back draft flap.Also check transformer if it has the old g60 gray box on top of gas valve.Check voltage at valve
Dec 30, 2009 | Dryers
Jul 08, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryers Logo
323 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
