Question about Xerox Phaser 7760 Laser Printer
Fault code 004-350 marking device failure
I turned power off for a minute and back on but same problem exists
    Novelist:
  • 140 Answers
Sorry, Phasers need more than one minute to reset. You need to turn off and unplug the printer for 30 minutes, then plug it back in and power it up. That might reset the printer.
Posted on Jan 02, 2015
What must we do to rectify an F8 fault?
I went to the roof and turned the unit off, waited a minute and turned it back on and the unit worked fine after that. It was a power failure that messed ours up.
Jun 03, 2014 | Carrier 36KCARMS Air Conditioner
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
1998 GMC JIMMY SLE PASSENGER AIRBAG LIGHT STAYS ON ALL THE TIME HOW DO I RESET IT
If there is a current failure in the airbag system, you can't reset it. The light will stay on for as long as the fault exists. You can plug GM's Tech 2 scan tool in, clear the code, and the light will turn right back on if the fault is still present in the airbag system. The only way to turn the light off (besides putting black tape over it) is to read the diagnostic code, diagnose the problem, and fix it.
Sep 23, 2013 | 1998 GMC Jimmy
F! fault on Tappen range
I am assuming that by F! you meant F1. If this is the case it is a generic fault code meaning that the EOC (electronic oven control) is bad and needs to be replaced. It can be caused by any number of different things or by absolutely nothing at all. Sometimes these computer boards sense errors that don't actually exist. I would suggest turning power off to the unit for at least 2 minutes to perform a soft reset on the control. This will clear any error codes that the computer has stored and will be restarting from scratch. Sometimes this can be enough to solve the problem. If the error code comes back after the unit is powered on then you will need to replace the EOC to fix the unit.
Nov 15, 2012 | Tappan Ovens
1986 dodge aries starts and dies after 2 minutes the lost of power light is on can somebody help please why is doin this? the pcm is stopping the fuel pump so the car dies i try sprying alcohol in the...
My Chilton book doesn't have a lot on vehicle specific emission controls. What I did find is this. Apparently the "loss if power light" will turn on if the temp sensor wire has been removed and then reattached. Have you recently done work at the thermostat? The temp sensor is mounted on the thermostat housing. To turn the "loss of power light" off, disconnect the positive battery terminal and then re-attach it. No waiting. Start the engine and then shut it off. After that turn the key ON and OFF several times to clear any fault codes in the computer. This may help because stored codes make the computer think the problem still exists and it reacts accordingly. Hope this helps.
Oct 07, 2011 | 1986 Dodge Aries 4 Door
F-01 code on a whirlpool front load washer
Frontload failure code
F-1 EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error still exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU.
Sep 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi..i cannot get my unit to turn on..there is power..but none of the buttons will activate. there is a code that shows in the display 12PF? HELP!
I am assuming that PF is a power failure, unplug unit for about ten minutes and plug it back in. Hopefully this will clear your fault. Some units have a small red reset button on them,also. Hope this helps Tim
May 29, 2011 | Heating & Cooling
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Has code PF and will not start Beeps constantly
PF means a power failure has occurred.
Press and hold the cancel button for several seconds to clear the error. Then press start. If the problem still exist you can unplug the unit wait several minutes an plug it back in. If the error still appears the control board maybe at fault.
Nov 12, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
Xerox Phaser 7760 Laser Printer Logo
104 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
