Question about Sunforce Electronics - Others
Screen says inL
Wont run 110 plugins
Acerall in on computer my screen at start up my screenhas inl two separated lines on my screenat start up why
Are they small red and blue lines caused by a damaged screen or bad video chip
Oct 14, 2014 | Computers & Internet
Vids wont play all way thru
try using different browser like Internet Explorer, Chrome or Mozilla.
Else use AdBlocker plugins to stop adv. hope this will help..
If you get green screen instead of video on YOutube, just right click on the video screen and correct the settings.
Jul 08, 2013 | YouTube Videos
White Screen In Dashboard
Hello Harmanrainu, First I do want to point out that majority of WordPress issues that involve white screens are mostly caused by php and database issues. IF you have access to your database via PHPMyAdmin, what I would suggest is to run through a check on tables, to verify that your tables are not corrupted or missing data. steps to do that are here: Repair and Optimize MySQL Databases with PhpMyAdmin Tutorial
Once you do that I would also run through and check the following:
A Plugin may be causing compatibility issues. If you can access the Administration Screens try deactivating all of your Plugins and then reactivating them one by one. If you are unable to access your Screens, log in to your website via FTP. Locate the folder wp-content/plugins and rename the Plugin folder plugins_old. This will deactivate all of your Plugins. You can read more about manually deactivating your plugins in the Troubleshooting FAQ.
Your Theme may be causing the problem. This is especially likely if you are experiencing the "WSOD" after you have just activated a new Theme. Log in to the WordPress Administration Screens and activate the default WordPress theme. If you can't access your Administration Screens, access your website via FTP and navigate to the /wp-content/themes/ folder. Rename the folder for the active Theme.
This should resolve any white screen problems
Knowledge is power
Jon Justiniano
Customer Service rep with:
Web Hosting Dedicated Server Hosting Domains AIT com
May 23, 2013 | wordpress.com Computers & Internet
The black inl isn't printing out only the colour
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 01, 2012 | Canon Sealed Pixma Mx870 All-in-one Inkjet...
My hp mini110 wont boot up how can i fix it
Turn OFF the Notebook and once its powered ON, keep Pressing F10 to load BIOS screen of the Notebook. In this screen under Diagnostics, run the test on hard drive and memory. Post back the results here.
Sep 11, 2012 | HP Pavilion 110-1030NR Notebook
Treasure madness
Chrome has two versions of Flash running at the same time causing issues with Treasure Madness in Facebook, the fix is to disable the Chrome version of Flash and keep the Macromedia...
type the following into the address area of the browser
chrome:plugins
Then disable the Flash that has Chrome in the location address
Aug 06, 2012 | zSlide Treasure Madness
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
When the care is cold it shifts but when it is hot it wont go into drive inles i put it in revers bring the rpms up and then it bangs in to revers
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????7
Jul 28, 2011 | 1992 Ford Taurus
My mp3 player is frozen help!! it won't do anything
Try to reformat it. It might be a virus or a bug.
Apr 27, 2010 | Sylvania SMPK8858 MP3 Player
No Power
yes
go to your fuse box if 220 flip both switches if fuse engaged there will be like a red line or fully difused down to show that fuses has been triped
if 110 your going to be flipping switches alot cause 110 runs both motor and guages together and over power is usually the cause of this
220 circuit one 110 runs the guages and the other 110 runs the motor and heater core
also washer wont run with out the water being on saftey feature
Nov 12, 2007 | Maytag LSE7806A Top Load Stacked...
Electronics - Others Logo
44 people viewed this question
Top Sunforce Electronics - Others Experts
Robert Hunt
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
