Xs2000 logic system
The stepper, The counter is on, but it says 1. 0 22:0 How can I get it to work
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Use a magnet, hammer, and hacking abilities. Ask google or siri.
Posted on Apr 12, 2014
My heater is stuck on the windshield and floor what actuator needs to be changed
Air Distribution
The HVAC control module controls the distribution of air by the use of a defrost actuator and a mode actuator. The modes that may be selected are:
Defrost
Defog
Panel
Bi-Level
Floor
The mode and defrost actuators are connected to the mode and defrost doors by a cam type linkage system. Depending on the position of the door, air is directed through the HVAC module and distributed through various ducts leading to the outlets in the dash. If the HVAC control module detects a fault with the mode or defrost doors the HVAC control module will try to drive the actuator for a predetermined amount of time, to defrost, which is the defaulted position for the mode and defrost door actuators. When the mode switch is placed in the defrost or defog positions the A/C is commanded on and the recirculation door is moved to the outside air position to help reduce window fogging. A/C is available in all modes and recirculation is only available in the panel and bi-level modes.
Circuit Description The following DTCs are for the HVAC door actuators: ?€¢
B0248 is for the defrost actuator.
B0263 is for the mode actuator.
B0408 is for the left air temperature actuator.
B0418 is for the right air temperature actuator.
The HVAC control module controls the HVAC door actuators to regulate the airflow through the HVAC system. Each actuator consists of a stepper motor, a logic circuit, and a potentiometer. The potentiometer inside the door actuator allows the module to monitor the current position of the actuator drive shaft. The logic circuit inside the actuators receives control signals from the HVAC control module and controls the internal stepper motor. When a door positional change is required, the HVAC control module calculates a commanded door position. The module compares the commanded door position to the actual door position and determines the needed direction of motor rotation. The module applies a signal voltage to the door control circuit that is an input to the internal logic circuit of the door actuator. A 5 volt signal increases the door position. A 0 volt signal decreases the door position. When the commanded door position is equal to the actual door position, the HVAC control module sends a 2.5 volt signal to the door actuator and motor rotation stops. The ignition 3 voltage circuit provides source voltage to the logic circuit. The module provides ground to the actuator logic circuit through the low reference circuit. I would start by having the HVAC control module checked for DTC'S -diagnostic trouble codes First . Then check the system by using scan tool data . 1
Did you perform the HVAC Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - HVAC Systems - Manual
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the appropriate HVAC door actuator ON and OFF while observing the corresponding Door Actual parameter.
Does the scan tool indicate that the value of the appropriate Door Actual parameter changes?
Go to Diagnostic Aids
Go to Step 3
I would
Apr 02, 2016 | 2003 Chevrolet TrailBlazer
Kodak I1X09 fault code
I1X09 One Line Description: INSERTER SUPPLY 3 stalled when it was moving down Error Type: Soft Shutdown Error Description: If the ELEVATOR STEPPER MOTOR uses more than 130% of the maximum number of steps to move the PLATFORM of INSERTER SUPPLY 3 down to the expected position, the INSERTER SUPPLY CONTROL BOARD determines that the PLATFORM has stalled. An I1X09 error code is recorded in the error table and you must either use another INSERTER SUPPLY or press OK on the OCI to clear it. Theory guide: I1INSER1 Possible Causes:
1 The input to LOGIC and CONTROL from the DOWN LIMIT SWITCH is not correct. 2 The input to LOGIC and CONTROL from the PAPER FED SENSOR is not correct. 3 Mechanical binds in the ELEVATOR DRIVE SYSTEM 4 The input to LOGIC and CONTROL is not correct. 5 The FLAT CABLE is damaged. 6 Circuit for the ELEVATOR STEPPER MOTOR is not operating.
Nov 20, 2013 | Kodak Digimaster Ex110, Same As Canon Ir...
I have a tony little rock n roll stepper and the LCD counter is not working. How do you repair it?
Obvious question, did you try a new battery?
You can also try cleaning the battery compartment in case of loss of the contact between the battery and the holder.
Oct 23, 2013 | Sport & Outdoor - Others
Kia mentor 2000 rev counter works on and off
The rev counter of course is electronic, most likely the tiny DC motor (called a stepper motor) that moves the counter is defective or the circuit for it is, you need to remove the instrument cluster from the dash and send it out for repair at a approved repair center. Many of these sites can be found by just a google search.
Nov 05, 2012 | Cars & Trucks
How do I get a new mp830 waste ink absorber for my mp830 printer?
The "waste ink absorber" in these models is just a length of cotton inside the printer that absorbs the waste ink. Usually they are rinsed and dried and replaced, and the printer is reset. I do not know of anywhere to get new ones
Sep 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Speedo & miles not working on my clocks
Possible defective speedo needle stepper motor. This is the little electric motor that moves the speedo needle and turns the mileage counter.
Oct 20, 2017 | 2003 Kia Sedona
Perfdisk problem
try typing this at a command prompt and reboot
diskperf -y
DISKPERF [-Y[D|V] | -N[D|V]] [\\computername]
-Y Sets the system to start all disk performance counters when the system is restarted.
-YD Enables the disk performance counters for physical drives when the system is restarted.
-YV Enables the disk performance counters for logical drives or storage volumes when the system is restarted.
-N Sets the system to disable all disk performance counters when the system is restarted.
-ND Disables the disk performance counters for physical drives.
-NV Disables the disk performance counters for logical drives.
Nov 06, 2007 | Microsoft Windows Server Standard 2003 for...
Lock On Error
Um just as a thought, but often there is a physical "head Lock" thats used when transporting the unit, are you sure this hasn't been activated? Just a thought.
Aug 09, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
