Question about Mitsubishi WD-73732 73" Television
Status light flashes with sound no picture
Sound but no picture
    Scholar:
  • 195 Answers
Try a new PHILLIPS blub and see if it helps. DO NOT use a neolux--they will NOT work right !!
Posted on May 08, 2014
73735 no picture no sound
Are you sure it is turning on? It sounds like your lamp has failed. Look at the LEDs on the front. If one is red then you need to check your lamp. Refer to the troubleshooting section of your manual to determine if the indicator LEDs match the symptoms. If the status light is flashing then your lamp cover is not installed all the way.
Feb 28, 2015 | Mitsubishi Televison & Video
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 | Cameras
The screen went blank and green light started flashing. Turned off the TV and let it cool. Turned it back on, getting sound but no picture. Red light is on, after about 15 seconds the green light blinks...
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Feb 25, 2011 | Toshiba 52HM95 52" HDTV Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
The lamp yellow light keeps flashing so nothing works
you need to make sure the door is all the way tight. there is a switch there and if it is not making contact you will get a yellow status light
Feb 22, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-73732 73" Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
